MC-7P Dared Pre amp with remote and phono input
2 posters
MC-7P Dared Pre amp with remote and phono input Empty MC-7P Dared Pre amp with remote and phono input
Post by analogaudiolabs Wed Jan 22, 2014 8:29 am
The tube covers (shielders) are coated with 18K gold (since all signal tubes are shielded, the preamp is very quiet -- one of the quietest MM phono preamps). Tube socket and PCB are planted with 18K gold too (no oxide issue here, best contact and connection). All signal wires are pure silver. The circuit design is very complex (Three tubes are used in power supply section in the circuit), Dared engineers and audiophiles worked together to collect best designs available and optimized this one with state-art technologies by computer programs. Here is, you simply cannot get better one with this price, period.
This excellent pre-amp is available at  [You must be registered and logged in to see this link.]
MC-7P
Now going for  SGD 1200/-.
MC-7P Dared Pre amp with remote and phono input 509_2_Dared_MC7P
MC-7P Dared Pre amp with remote and phono input 508_2_Dared_MC7P
Some reviews here: 6 Moons Review
MC-7P Dared Pre amp with remote and phono input MC_7P_4a8fc7a1dbf8d
Signal to noise ratio: 93 dB
Signal to noise ratio(MM): 75 dB
MM gain: 39 dB
Tubes: 12AX7 X 4 nos, 12AT7 X 1 no, 6P6P X 1 no, 5Z3P X 1 no
Size: 34 cm X 29 cm X 16 cm
Weight: 12 Kg
 Call +65 83195040 if interested
It uses 7 tubes and has two huge separate (yes separate--- only Dared design this way. Simply the best) power transformers: one for high DC volt and one for low volt of tube heaters and others. The capacitors use Audiophile grade and the key resistors use NOS AB and Vishay non-inductive. The tubes come with the amp are Chinese stock Ruby tubes.
Visit  [You must be registered and logged in to see this link.]   for more models
analogaudiolabs
Number of posts : 263
MC-7P Dared Pre amp with remote and phono input Empty MC7
Post by fireballmivec6315 Thu Jan 23, 2014 11:36 am
XLRs output to power amp?
fireballmivec6315
fireballmivec6315
Number of posts : 285
Registration date : 2012-02-24
MC-7P Dared Pre amp with remote and phono input Empty Re: MC-7P Dared Pre amp with remote and phono input
Post by analogaudiolabs Mon Feb 17, 2014 10:45 am
analogaudiolabs
Post by analogaudiolabs Thu Mar 06, 2014 8:36 am
analogaudiolabs
Post by analogaudiolabs Mon May 12, 2014 8:27 pm
Call / msg +65 83195040
analogaudiolabs
