YULONG SABRE DA8 32bit 384khz DSD DAC
Yulong Sale ~ DA8 DAC, P18 power,
YULONG SABRE DA8 32bit 384khz DSD DAC/Balanced Pre-amp/Class A headphone Amp
Reviews by Project86.
Review on DA8
YULONG SABRE DA8 32bit 384khz DSD DAC RM4150
Specification:
THD+N less than 0.0003%, dynamic > 130dB, Idle noise 1.5uV
USB supports 32bit, 384KHz PCM signal
DSD native support
5 different filter mode
Invertible phase
Jitter eliminator switch
Filter, phase, jitter control switch. Different style of sound under different combination
High precision bandwidth-auto-set DPLL
80 steps volume control
Single/Balanced pre-amplifier output
Balanced pre-amplifier output with driver, can be used as balanced headphone amplifier
Work as pure DAC when headphone amplifier and pre-amplifier circuit turned off
Class A single end headphone amplifier
TFT LED display. Easy operate. 80% dim after 5 seconds
Auto-save configuration
Thickened aluminum case. Aluminum button, volume knob and feet
100v-240v global voltage range
Technical Specifications :
USB Input format support: PCM 16-32bit 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
Operating system support Mac OSX Linux with UAC2 compliant kernel.
KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit
Inputs: Optical, Coaxial, AES/EBU:16-24Bit,44.1-192KHZ
SNR: -135dB.
Dynamic Range: >130dB.
THD+N: 0.0002%
Frequency Response: 20-30KHz-0.2dB
Crosstalk -135dB
balancedOutput level:4.2V
Headphone amplifier output power: 600Ω:70mw 300Ω:150mw 150Ω:280mw 32Ω:1W
Power consumption: <30W.
weight: 2.5Kg
P18 Power Processing Center Retail RM910 only Black left
P18 uses an enormous ferrite core, winded with 11 AWG Pirelli wire.
Vishay 8uf X2 MKP as common-mode filter
Vishay Sprague Y2 as differential-mode filter
Vishay transient voltage suppressor is used for avoid sudden impulsive noise signal
LITTLEFUSE varistor (VDR) is used for absorbing voltage surge
Double layer parallel wide traces on PCB with 20 ounce copper.
11 AWG Pirelli wire is used for internal wiring.
Schurter IEC inlet socket
Cooper IG8300 receptacles
Specially designed aluminum enclosure provides great Electromagnetic shielding
Two groups of output, separates digital and analog equipments
Phase and grounding error LED indicators
D230 Power cords Retail price RM390
Both of the power cords are based on cable from Lapp Kabel Germany and terminated with Marinco 5266 and Schurter 4781. With high quality parts and high standard flexible cable, they are very easy to use and last for a very long time. Acoustically, D230 produces detailed, balanced and musical sound.
Clearing at RM780
A100 is a class A transistor headphone amplifier, which is carefully designed: The power comes from a high quality, custom made transformer with selected core material, then through a four-way regulating circuit, the voltage and current amplification stage are powered separately. This is to ensure the signal process is not interfered by power supply fluctuation.
The input signal is buffered by an AD827, to reduce the dependence of the signal source as well as the interconnection cable. The low impedance signal from buffer stage feeds into volume control, and then amplified by an OPA627BP (voltage amplification) and a class A transistor buffer constructed with BC557/567+MJE243/253 (current amplification). The output is separated in 2 ways, one for high impedance headphones (direct output) and the other one for low impedance headphones (in serial with 120Ohm resistor).
Review on DA8
Specification:
DSD native support
Invertible phase
SNR: -135dB.
THD+N: 0.0002%
Crosstalk -135dB
weight: 2.5Kg
Clearing at RM780
Skylines Audio- Dealer\Reseller\Trader\Service Provider
- Number of posts : 185
Registration date : 2012-10-24
» ★ Yulong DA8 II ★ DSD, 32bit/384kHz USB DAC (New)
» Yulong Sabre 18 Dac
» Yulong Sabre P18
» Musiland Dragon with True 32Bit/384kHz DAC(used)
» Yulong Sabre P18
