Matching Naim products
Post by durianking1 on Fri Nov 13, 2009 5:22 pm
i am new to naim. can i ask anyone, if you get a full naim system, do you have to match it eg. if you have a nait 3 integrated amp, is it better to get a cd3 player; if you get a nait 5i amp, is it better to get a cd5i player; certain preamps matches with certain amps and cd players and power supplies,etc etc. OR it doesn't matter, as long as they are the same generation? is there info on the internet on this?
durianking1
Male Number of posts: 7
Registration date: 2009-10-03
Re: Matching Naim products
Post by lewce1 on Fri Nov 13, 2009 6:35 pm
Go to www.naim-audio.com
Look into suggested systems under products.
Just follow, based on your budget.
Play it for 3 good years and you are in seventh heaven.
This is short cut, don't waste time mix and match with different generation.
Good luck.
lewce1
Male Number of posts: 108
Registration date: 2009-01-21
Source(s): Naim CDX-2 and XPS
Amplification: Naim NAC 282 / NAP 250.2 / HiCap
Speakers: Naim Allae
Post by lewce1 on Fri Nov 13, 2009 6:50 pm
Also never mix pre and power combi even within the same generation. Earlier 202/200. later upgrade power to 250.2. cannot tahan, all the roughness of 202 is amplified glaringly. No choice have to get 282 pre.
lewce1
Post by durianking1 on Fri Nov 13, 2009 9:42 pm
thank you very much for the advice so far folks. appreciate it!
durianking1
Post by mugenfoo on Sun Nov 15, 2009 2:09 am
naim pre & power combos are best partnered among Naim's own models.
A non-naim pre amp partnered with a Naim power-amp has a certain risk such that gives rise to instability in the Naim power amp and can even destroy the power-amp.
How is this possible? It's to do with the design of Naim's amps and something called "capacitance".
mugenfoo
Male Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Post by car o scope on Wed Nov 18, 2009 10:09 pm
Must also buy the Naim cables??
car o scope
Male Number of posts: 1056
Registration date: 2009-01-19
