Emotiva XPA-3 Power Amplifier (SOLD)
Dear all,
It's time to add more power to your AV System,.....
Brand : Emotiva
Model : XPA-3
Condition : 9/10 (like new, comes with original and double layer packing box from Emotiva)
Weight : approx 26KG (heavy) =="
Asking Price : -SOLD-
SPECIFICATIONS (a courtesy from Emotiva.com)
-Number of channels: 3
-Input impedance:
-unbalanced: 47 kohms
-balanced: 33 kohms
-Transformer rating: 850VA
-Secondary capacitance: 60,000uF
-Output devices: 6 per channel
-Amplifier gain: 32 dB
-Signal to Noise Ratio
-1 watt: > 98 dB
-Full power: < 112 dB
-Topology: fully discrete, dual differential, high current, short signal path Class A/B
-Power output (all channels driven):
-300 watts RMS @ 4 ohm (0.1% THD)
-200 watts RMS @ 8 ohm (0.1% THD)
-Rated power bandwidth: 20 Hz to 20 kHz with less than .05 dB deviation at rated power
-Broadband frequency response (-3 dB): 5Hz to 150kHz
Size:
-unboxed: 17” wide x 7.75” high x 19” deep
-boxed: 23.25" wide x 11.5" high x 24.5" deep
-Weight: 57 lbs (72 lbs boxed)
Other Features:
~Fully protected from all fault conditions
~Soft start circuitry
~External trigger turn on
~Soft touch power switch
~4RU chassis w/ solid milled aluminum faceplate
~IEC power inlet, 120/230 VAC configurable
~Output design: Triple Darlington with On output stages
~Differential Drive: Dual Differential input
~Types of inputs: Balanced (XLR) and Un-balanced (RCA)
~Type of outputs: Audiophile quality 5 way binding post
~Display type: Digital status indicators
Thanks for Looking....
Cheers...
Brand : Emotiva
Model : XPA-3
-Input impedance:
-balanced: 33 kohms
-1 watt: > 98 dB
Size:
Other Features:
Cheers...
tkhoo60- Frequent Contributor
- Number of posts : 220
Registration date : 2011-07-15
Source(s): Teac VRDS-10, Philip CD850 MK1, Musical Fidelity A3.2, Marantz CD-63SE, Pioneer PD-F507
Amplification: Luxman M-2000, NVA AP-35, JC Audio KT-88, Sansui AU-2200
Speakers: Monitor Audio Silver 7i, LST Basik, Castle Warwick
Re: Emotiva XPA-3 Power Amplifier (SOLD)
Dear all,
glad that Item has been sold this afternoon to a nice gentleman...
enjoy your new toy..
cheers..
cheers..
» Emotiva XPA-3 Power Amplifier (SOLD)
» Emotiva XPA-3 power amplifier (SOLD)
» Emotiva XPA-3 Power Amplifier [SOLD]
» Emotiva XPA-5 Five Channel Power Amplifier [SOLD]
