QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m
QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m Empty QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m
Post by raymond88 Sat Mar 29, 2014 3:57 pm
Item: QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m
Condition: 8.5/10
Price: RM150 or swap with your cables
Contact: 012-3816611  Raymond
QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m Qed110
QED Qunex P75 Digital 75 Ohms Co-Axial RCA Interconnect - 1m Qed10
Some info:
QUNEX P75 delivers the clarity and realism you expect from a top-flight Co-ax interconnect at a budget price. That's because it doesn't cut corners. It gets it right. Optimum transmission line performance demands an impedance of exactly 75 ohms. And to achieve that requires precision - a cable built down to tolerances of 100th of a millimeter, not down to a price. A cable designed for the job.
QUNEX P75 is exactly that - an accurate 75 ohm digital interconnect. Signal and data integrity is ensured by using a low loss LDPE dielectric and 99.999% Oxygen Free Copper (OFC) conductors. A PVC jacket absorbs mechanically induced vibration and a triple screen comprising aluminium Mylar foil and dual 99.999% OFC copper braids prevents electrostatic and electromagnetic interference. The zinc plated alloy phono plugs are ergonomically shaped and use gold-plated pins and connectors to minimise contact resistance and oxidisation.
QUNEX P75 does exactly what a video/digital interconnect should - preserves fully intact the information passing along it and rejects noise. It takes care of the technicalities. Your attention will always return to the experience.
http://www.hifix.co.uk/discontinued-products.lasso?item=0898ac23f93495f052dccfac896e177a2996377340c55ac3
Thank you.
Number of posts : 10090
