Musical Fidelity F22 Valve Preamp (SOLD)
2 posters
For Collectors/ tube DIY Ethusiasts/ Audiophiles
This is a CLASSIC CLASS A VALVE PRE-AMPLIFIER from Muical Fidelity. It incorporates 4 x ECC88 valves. NO PHONO BOARD INPUT for this set as it is optionally fitted.
This beauty mellows down any system where the power amp or speakers are tend to brightness.
REVIEWS:
There is little to criticise and a great deal to praise about these units. In terms of its hi-fl potential, this is a winning combination without a doubt. - Review in GRAMPHONE, August 1994
“Did some listening last night - the sound 'as delivered' (old tubes, RCA single ended connections) is really nice to listen to. A real sense of musical flow, like the music is gliding along on well greased rails.“– Audiophile forumer
“As expected, the valves in there are almost certainly the originals from 20 years+ ago. And as expected they look like the usual 'no-name' dreck these companies use to save a few pennies. Swapped them out for four pcc88 valves - 2 from Telefunken, 2 from Tessla. Oh my golly gosh - I had liked the pre before, but now the musical textures are more solid; colourful, the soundstage images are so much more 3D and vivid. I'm a bit stunned by the leap in sound quality. It's amazing what a bit of tube rolling can do!” - DIY Addict
“Surprisingly detailed and fast, especially for the money. Good focus, well defined. A great value though for acoustic music (classical especially).
A very "nice" pre to listen to, lots of well-focused detail.
A really good looking piece of kit as well”
- Reviewer HifiAudiophiler
Specifications :
Type.................................................Class A
Tubes...............................................4 x 6922/6DJ8/ECC88
Weight..............................................8kg
Dimensions(w x d x h)........................48.5 x 32.5 x 11.5cm
Frequency response not specified (20Hz-20kHz, -0- 1 8dB)
Input sensitivity (for lv output) line-level 235mV
Total harmonic distortion (1V output)
SOLD to a nice gentleman in Pahang!
Condition: 7.9/10 (well kept after all these years, a gem)
Place: Penang
Contact: Wong 012-40 nine nine nine 88 (sms or whatsapp for faster response)
Method: C.O.D or Bank in and courier
Packaging: Double boxed with ample cushioning for transport
Tracking: We will follow up with you until safe delivery of goods in your hand.
Kewl Hifi
Enjoy our first grade advice and service : )
REVIEWS:
Specifications :
Place: Penang
Kewl Hifi
kleew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 68
Registration date : 2013-10-02
Re: Musical Fidelity F22 Valve Preamp (SOLD)
Perhaps the most important weapon in the arsenal is a black plastic wedge which comes with the F22: a remote control. The F22 is not the first-ever remote control pre-amp, but I can't think of another all-tube (ECC88s) line-level pre-amp with balanced operation, relay switching, bomb-proof construction and infra-red operation which sells for £999. Yes, three -- not four -- nines. And there's no obvious corner cutting, either. The switching feels great, the knobs are beautifully chromed and there are multi-coloured LEDs to indicate states of operation from warm-up to full 'on' to mute. Musical Fidelity fitted top quality sockets at the back, there's an easy-to-access toggle switch to choose between balanced (XLR) and unbalanced operation, the circuit is Class A triode linear cascode with separate regulation for each channel (DC and HT) and the layout is designed for maximum isolation of the various stages. I was told, too, that the F22 should prove immune to external influences and it did prove to be rather unfussy when it came to siting and cable selection. Its 480x335x105mm (WDH) is solid, chunky, serious.
http://hometheaterreview.com/musical-fidelity-f-series-power-amps-reviewed/
Price revised RM2499!
For Tube DIY enthusiast, Price Reduced RM2300!!!!
Price Reduced RM2,200!!!
mf 22
hi is it still available at 2k.....items is it in penang malaysia.kleew wrote:Price Reduced RM2,200!!!
best regards
eddie
eddiechew@live.com
dyland- New Member
- Number of posts : 2
Registration date : 2011-08-18
Sold to a very nice gentleman in Pahang. Thanks for keeping up with this topic. Regards.
» Musical Fidelity CDT valve cdplayer (SOLD)
» Musical Fidelity CDT Valve CD Player (Used) SOLD
» MUSICAL FIDELITY CDT VALVE CD PLAYER (SOLD)
» Musical Fidelity X-10v3 valve buffer (Used)SOLD
» Musical Fidelity preamp 3A mkIII preamp & P 180 power amp(Used)SOLD
