Luxman PD-272 Turntable with ADC LMF-2 ToneArm and QLM 36 MKIII Cartridge (Used)
Made In Japan
DC-Servo Direct-Drive Turntable (1980-1982)
Description
The Luxman PD272 is a two-speed, manual turntable using a DC servo motor direct-drive system.
Slots are completely removed to eliminate unevenness of rotation caused by electromagnetics, and further provided is a turntable platter of high inertia with which the large mass of the platter weight is distributed around the outer contour.
For the tonearm, a straight type is adopted to eliminate resonance caused by lack of solidity which tends to be found on the tonearm exclusively designed for high-compliance type cartridges.
Driving method: direct-drive
Motor: DC servo brushless and slotless
Platter: 30cm aluminium die-cast 1.8kg
Speeds: 33.33 and 45rpm
Pitch control: +-4%
Signal to noise ratio: better than 60dB
Wow and flutter: no more than 0.03% WRMS
Tonearm: straight arm of static balance type
Effective length: 240mm
Overhang: 15mm
Cartridge weight: 4-11g
Stylus pressure: 0-3g (direct reading)
ADC LMF-2
Description
The ADC LMF-2 is the removable headshell version of the LMF-1 tonearm.
The headshell uses a knurled screw to clamp the platform in place.
Effective length: 237
Overhang: 15mm
Mounting distance: 222mm
Effective mass: 6g
Headshell: removable
Bias compensation: spring applied
Review
The LMF-2 arm is very easy to use, especially while making adjustments during tests. The mounting of the arm to the turntable is not difficult compared to some other arms. Mechanical aspects of the arm are generally quite good - $215 Audio 1979
ADC AUDIOPHILE PHONO CARTRIDGE
SPECIFICATIONS:
•Output voltage: 6.05 mV per channel at 1 kHz.; 5 cm./sec. peak recorded velocity.
•Channel balance: 2.0 dB at 1 kHz.
•Channel separation: 24 dB at 1 kHz.
•Frequency response: 15-20 kHz ± 2 dB.
•Tracking ability: 80 µm at 315Hz at recommended tracking force.
•Stylus type: Elliptical.
• Stylus tip radius: 0.3 mil. x 0.7 mil. Elliptical.
• Tracking force range: 1.5-3.0 grams.
•Recommended tracking force: 2.25 grams.
•Tracking angle: 20°.
•Optimum load: 47, 000 ohms resistance in parallel with 275 to picofarads total capacitance.
•Cartridge weight: 5.75 g.
•Mounting: Standard 1/2" (12.7mm) Mounting Centers.
•Replacement stylus: RQLM36.
Note: The Turntable Plinth had been upgraded to Polycarbonate
Price : RM 2250
- Number of posts : 2967
» Luxman pd310 turntable + fidelity research fr64fx tonearm SOLD
» Luxman PD282 Turntable with SME 3009 Tonearm Sold
» Heybrook TT2 turntable with Tonearm and cartridge (SOLD)
» Rega RP3 Turntable, RB303 Tonearm with AT MM Cartridge (Used) SOLD
