Odyssey Khartago Stereo Extreme SE Power Amplifier (Used) SOLD
Up for sale an Odyssey Khartago Stereo Extreme SE power amplifier, hardly used as I bought this amplifier intended as back up amplifier for my Maggies 3.7 when the Passlabs were up for sale. Have no issues driving the Maggies.
Have confirmed with Klaus Bunge via email that this is the Extreme SE version.
Excerpt from a review:
"Why am I talking about the Soulution amplifiers in a review of Odyssey gear? Because I heard about both from solid-state-amp connoisseur Alon Wolf of Magico. I wasn’t a bit surprised when he recommended the Soulution 700s—they cost a fortune and had a helluva reputation for excellence. But I was surprised when he suggested that I also give a listen to a little amp called the Odyssey Khartago. First of all, I’d never heard of Odyssey, though, as it turns out, the company’s been around for a decade, and second…well, I’ll get to that in a moment.
“I’ve been using the Khartago in the factory for years,” said he, “to test loudspeakers. It isn’t a Soulution 700, but it’s…good enough.” Good enough for the Wolfman is good enough for me, thought I, and promptly called Klaus Bunge of Odyssey..."
Check out:
http://maxx-ht.blogspot.com/search/label/Odyssey
(sorry Max & Ben )
Full review here:
http://www.theabsolutesound.com/articles/tas-195-odyssey-audio-khartago-stereo-amplifier/
Specifications:
2 x 110 Watts RMS @ 8 Ohms
2 Ohm load stable
Class A/AB
2 - 400,000 Hz frequency range
120,000µF memory
40 amps current delivery
<0.04% THD (not audible)
>500 continuous damping factor
Input impedance 22K ohms
DC offset <1 mV
RCA inputs
400 VA Plitron transformer
Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
Anti vibration dual thickness PCB
Power consumption when idle ±30Watts
4 internal fuses 250V/6.3A, 5x20mm, fast blow
Higher performance parts:
Nichicon Muse capacitors, Vishay/Dale resistors, extra WIMA metal film capacitors
Condition: 8/10 (silver) (conservatively rated, with box)
Price: SOLD. Thank you to a fellow enthusiast and a gentleman to boot.
Contact: 013 333 6366 (calls/SMS/Whatapps/Telegram/Kakao)
For some reason, I am still unable to upload photos but will send to you with the appropriate mobile apps. Thanks for looking
Check out:
(sorry Max & Ben )
Full review here:
Specifications:
2 Ohm load stable
Class A/AB
120,000µF memory
DC offset <1 mV
RCA inputs
zeebee- Frequent Contributor
- Number of posts : 563
Registration date : 2009-02-05
» Odyssey Khartago Stereo Extreme Special Edition Power Amplifier
» Odyssey Khartago Extreme Special Edition Power Amplifier
» Odyssey Stratos Stereo Extreme power amp (SOLD)
» Odyssey Khartago SE stereo amplifier
