Meridian Boothroyd Stuart 101 Pre-Amplifier and 103 Power amplifier (Sold)
Made In England
As you know, these don't come onto the market very often !
No software, no RS232 ports, no multi-channel and no gimmicks!
Just watertight engineering principles intelligently applied to achieving the goal of musically realistic listening. Those were the days. They truly were.
An absolutely outstanding sound and a true credit to legendary British HiFi makers Meridian.
There are probably only a few modern units that could touch this in terms of sound reproduction.
On top of that it looks amazing, make sure you have some decent speakers to match to this.
On no account be deceived by it's 45w per channel spec, this hifi will not only go louder than physically bearable but the sound is undistorted through the whole volume range, absolutely crystal clear
SET UP
The units are designed to dissipate heat through their metal bodies.
they can be stacked horizontally or vertically
Check the manual for optimum positions, this equipment has to be set up properly for optimum performance
(that also includes the positioning of the amps!)
VOLTAGE
Can be set up to 110 or 240v, currently set up as 240v -UK
MANUALS
Are available online
MANUALS
I have included links to workshop manuals in this ad, the set up is a little arcane so I would suggest having a good read before you plug anything in. This is a case where you must definitely read the manuals!
101 controller
http://www.meridian-audio.info/public/meridian_101_103%5b405%5d.pdf
103 amps
Price : RM Sold
Last edited by HiFiLab on Sat Sep 06, 2014 11:14 am; edited 2 times in total (Reason for editing : sold)
- Number of posts : 2967
» Boothroyd stuart meridian 101 control unit & Boothroyd stuart meridian 105 mono block power amp (Used)SOLD
» Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair)
» Boothroyd-Stuart Meridian 101 Pre-Amplifier (sold)
» Boothroyd stuart meridian control unit 101 & 105 mono block power amp (Used)SOLD
» Meridian Boothroyd Stuart Control Unit + Power Amp
