DLS Audio Sub-3.10 Active Subwoofer (Display Unit)
DLS Sub-3.10 is an efficient, active subwoofer with a built-in 160 W highcurrent power amplifier. The loudspeaker unit is a specially designed 10" longstroke woofer with a powerful magnetic system.
DLS Sub 3.10 is designed to interact with Hi-Fi equipment, surround installations and multi-media systems. The subwoofer allows great freedom in placement. With the controls you can adjust crossover frequency, level and phase, whick makes it easy to adjust for the accoustics in your listening room. Made of high density MDF-board with good damping characteristics.
The Sub 3.10 is available in black or white. With the genuine built-in DLS quality and our attention to detail, the Sub 3.10 will bring you an excellent combination of compact size and premium sound quality.
Specification
Description / type | 10" active subwoofer in a 31 litres vented MDF-box |
Woofer size | 10 " / 25 cm |
Amplifier | 160 Watt high current analogue amplifier |
Phase control for subwoofers | 0-180 dgrees cont. variable |
Amplifier class | AB |
Low pass filter | 30 - 150 Hz |
High pass filter | 25 Hz |
Low level input | Yes |
Frequency range | 32 Hz - 150 Hz |
High level input with auto start | Yes |
Finish / colour | Black and white low gloss |
Dimension (W x D x H) | 350 x 334 x 440mm / 13,8" x 13,1" x 17,3" |
Weight | 20 kg / 44 lbs |
____________
Best regard
Steve Chua
+6012-6535703
+603-77266893
CMY Audio & Visual Sdn. Bhd.
S336, 2nd Floor,
1 Utama Shopping Centre,
(New Wing) Bandar Utama,
47800 Petaling Jaya.
» Audio Pro - B1.28 Subwoofer (Display Unit)
» Naim-N-SUB-Subwoofer(Display Unit)
» Audio pro-Mondial Sub S3-MK2-Subwoofer(Display Unit)
» Audio Pro-Sub Level 110-Subwoofer(Display Unit)
» BMB SW-800 Subwoofer. (Display Unit)
