Luxman PD-282 Audiophile Direct Drive Turntable ( Sold)
Made In Japan
Direct drive is recognized as the ideal method of rotating records for stable playback with minimal wow and flutter. It eliminates many defects to which belt and rim derive turtables are prone. The modern direct drive system employed in the PD282 is controlled by an electronic circuit which ensures wow and flutter of less than 0,03% (WRMS) and signal to noise ratio of better than 60 dB.
This puts Luxman amongst the highest class turntables available. As a result of the direct drive principle employed the incorporated speed variation allows accuracy of speed setting without affecting the ultimate performance possible.
The arm provived has extremely low bearing friction and comes with an idealcombination of simplicity and professional performance. Such sophisticated devices as lateral balance, antiskating control, easy to read stylus pressure gauge, oil damp cueing are amongst the features provided.
As well all units carrying the Lux name finish is immaculate. The meticulous care paid to selection of material and construction of cabinet makes the PD282 resistant to external disturbance and feedback.
The detailed precision in construction and appearance will ensure that your acoustic sensitivities and your aesthetic sensibilities will both be enhanced.
SPECIFICATIONS
PHONO MOTOR SECTION
Driving System: Direct-drive
Motor: AC-servo 6-pole condenser motor
Platter: 30 cm aluminium die-cast
Rotation: 33⅓ and 45 RPM
Adjustable range of Rotation: ±4%
S/N Ratio: No less than 60 dB
Wow and Flutter: No morethan 0,03% WRMS
TONEARM SECTION
Tonearm: S-curve static balance type
Effective Length: 237 mm
Overhang: 15 mm
Cartridge Weight: 4 - 12 g
Cartridge Height: 15 - 20 mm
Stylus Pressure: 0 - 3 g (direct reading)
Accessories: Inside-force Canceller, lateral Balancer, Tonearm Elevation
ADDITIONAL FEATURES
Dust Cover: Detachable with free-stop hinge
Insulator: height adjustable (10 mm range)
Stroboscope: Indicated on the outer edge of the turtable platter by means of neon lamp
GENERAL
Power Requirement: 120 V, 220/240 V, 50/60 Hz
Power Consumption: 12 W
Dimensions: 471 x 175 x 351 mm + 22 mm for hinge
Weight: 10 kg ( 22 lbs) Net, 12 kg (26,4 lbs) Gross
Luxman TD-282 direct drive turntable. Full manual audiophile TT, beautiful sound, gorgeous condition, super stable and solid TT. Very nice arm,
C.E.C Headshell With Rega Carbon Cartridge and stylus (NEW)
Price : RM Sold
Last edited by HiFiLab on Thu Nov 20, 2014 11:21 pm; edited 2 times in total (Reason for editing : sold)
- Number of posts : 2967
BUMP
UP
BUMP
UP
» Luxman PD-282 Direct Drive Turntable ( USED) - SOLD!
» Luxman Quartz Direct Drive Automatic Turntable PD291(Sold))
» Kenwood KD-550 Direct Drive Audiophile Turntable (Used) SOLD
» Kenwood KD500 Direct Drive Audiophile Turntable (sold)
» Sony Direct Drive Turntable PS T-15(used)Sold
