US to UK Plug Adapter With Reverse Polarity Feature
3 posters
Dear Sifus, can anyone share with us on where can we find a US to UK plug adapter with reverse polarity as i've googled for this product but to no avail...hope someone in this forum can assist me...
alternatively, is there a mains block / power distributor with reversed polarity for their US sockets so that i do not need to find the abovementioned plug adapter for use in M'sia...
many thanks for your guys reply...
alamdamai1- Regular
- Number of posts : 63
Registration date : 2011-12-28
Source(s): Marantz UDP 7007
Amplification: Cyrus 6a, Naim NAP 100
Speakers: KEF Q900
Re: US to UK Plug Adapter With Reverse Polarity Feature
The easiest way is to reverse the polarity in the plugs.
thx bro 4 ur reply...i've managed 2 find tis highly elusive plug adapter via a s'pore forummer in extremeplace where he had used yung li of taiwan (sold in d usa by sfcable) n vh audio where both adapters hv their polarity reversed..
alamdamai1- Regular
Speakers: KEF Q900
STC's suggestion is very economical and it eliminates the additional connections.
sph- Frequent Contributor
- Number of posts : 336
ha..ha...wish i cld tat but my plugs r custom moulded unless i cut them out n replaced wif bs plugs which i think may affect d cable performance...
alamdamai1- Regular
Speakers: KEF Q900
I did just that! I am avoiding adapters since one of the earthing wasn't working properly and I received a mild shock from the amplifier body (120V).
Also every extra connection adds more resistance which defeats the purpose of high end cables.
hee..hee...d vh audio adapters are cryogenic treated..
alamdamai1- Regular
Speakers: KEF Q900
In my opinion, a US-UK adapter would have the conductors inside the plug crossed in order to reverse the polarity.
After constant use of the adapter, especially with plugging and unplugging, the connectors can become loose and when that happens a short circuit could happen.
Perhaps that was what happened in STC's case.
For my power distributor I made the reversal connection inside the distributor for the US connections.
Cheers.
Cheers.
Cheers.
Cheers.
Hi SPH,
I was using a cheap US to UK adapter. Somehow, the earth pin did not make a proper contact to the US plug earth.
After that, I removed the Hubbell plugs and replaced it with our local MK plugs.
But I am not much of a cable believer so I am thankful to god for not hearing any difference.
haa..haa...u guys sure hv good sense of humour...
my cables r still on d way fr usa n will report its performance against my existing merlin huntsman soon...
alamdamai1- Regular
Speakers: KEF Q900
» USA-UK 3 Prong Plug Adapter with Correct Phase Polarity
» USA-UK 3 Prong Plug Adapter, US correct polarity, NEMA 5-15R receptable
» 2-Pin Euro Plug to 3-Pin UK Mains Adapter
» 3 Prong Plug Adapter USA NEMA 5-15R Receptacle
