KEF C10 British Near Field Monitor Bookshelf Speaker ( Sold)
Made In England
C10 (1985-88)
This tiny bookshelf speaker was the latest in the long and illustrious line that started with the famous Cresta system in the mid-1960s.
Using a B160 polypropylene coned bass/midrange driver to reduce colouration, the system was designed for wall or shelf mounting.
The result was a diminutive little box that sounded much larger and louder than it looked.
Specification: C10
- System Type: Two-way, bookshelf/stand-mount
- Enclosure type: Closed box
- Size: 300 x 205 x 172mm (11.8 x 8.1 x 6.8 inches)
- Weight: 3.7kg (8.2 lb)
- Nominal Impedance: 8ohms
- Rated maximum power: 60 programme
- Frequency response: 90Hz to 500Hz +/-3.0dB rising 3dB to 1kHz-20kHz +/-3dB (-6dB at 70Hz)
- Sensitivity: 88dB for a pink noise input of 2.83V (under wall-mounted conditions)
- Maximum output: 106dB on programme peaks under typical listening conditions
Finish: Black Ash
System: SP3057
Drive units: B160 bass unit (SP1199), T33 tweeter (SP1089)
Crossover: SP2057
Note : This Speaker Have Lucky Serial Number : 012888
Price : RM sold
Last edited by HiFiLab on Thu Jan 15, 2015 12:29 am; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
» JPW British Stereo Mini Monitor Bookshelf Speaker (Sold)
» TDL Near Field Monitor speaker SOLD
» TDL Monitor Near field Speaker (SOLD)
» TDL Electronics Near Field Monitor Speaker (SOLD)
» Rogers DB-101 Compact Size Studio Near Field Monitor Speaker (Sold)
