Denon DRW-695 Double Cassette Deck ( Sold)
Description
Details:
The Denon DRW-695 is an affordable double cassette deck offering a host of convenient, easy-to-use tape editing functions, such as Memory Stop that lets you automatically stop the tape at any desired location, and High-Speed Dubbing to copy tapes from Deck A to Deck B at twice the normal speed.
The Denon DRW695 also provides a backlight so that you can easily monitor the remaining amount of tape. In addition, the audio circuit includes a Bias Fine Tuning feature to ensure that each tape performs at maximum potential.
Of course, the DRW-695 is further equipped with Dolby B/C noise reduction systems and HX-Pro to minimize noise from the tape and eliminate distortion in the high range. Your ears will enjoy a sound that is both clean and rich.
The Denon DRW 695 provides a variety of playback and recording modes. Besides the usual Single and Reverse play modes, when the Relay Play mode has been selected and the Play button is pressed, deck A first starts playback, followed automatically by deck B after both sides of the tape in deck A have been played.
Two dubbing modes are provided: Normal and High-Speed. The latter mode copies tapes from Deck A to Deck B at two times the normal speed of tape travel.
A bias adjustment knob is provided on the front panel for greater control over recording characteristics. The center stop position provides the standard recording bias level, and turning the knob to the right or left will produce plus or minus variations in the bias during recording to suit the individual taste of the listener.
The CD Synchro record function allows you to easily make recordings from CD without performing separate operations on both the cassette deck and the CD player.
Auto Reverse. Auto Tape Selector plus Auto Space
IS Remote Control System (with Remote Sensor)
FL Peak Hold Level Meter
MPX Filter Switch
Specifications:
Cassette Type
Twin transport Deck
Finish :Gold
Weight :4kgs
Dimensions (HxWxD) in mm : 135x434x263
System Remote Sensor
Controls
Variable tape Bias
Auto Tape Calibration
Yes
Connections
Phono Line in / out
Filter
Yes MPX
Tape Direction
Auto Reverse
Dolby Noise Reduction
Dolby B plus Dolby C
Dolby HX
Yes HX-Pro
Note : In Very Good working Condition, just service and change rubber belt
Price : RM sold
Last edited by HiFiLab on Wed Mar 18, 2015 4:58 am; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
» JVC double cassette deck SOLD
» JVC TD-W318 double cassette deck (sold)
» JVC TD-W254 Double Cassette Deck (SOLD)
» Technics RS-TR252 double cassette deck(sold)
» TEAC W-790R double cassette deck - sold
