XTZ Floorstanding speaker
I have one pair XTZ Floorstanding Speaker for sale.
Model :XTZ 99.36 MKII Piano
Conditions :8/10
Color :Piano Black
Price :sold
Place :Perak
Contact :012-5020182 {Leong}
Used Period :6 Month because upgrade to XTZ 99.38 MKII
Construction type
2 1/2-way with separates boxes for woofer and woofer/midrange
Bass reflex cabinet that may be set as a closed box, a total of eight distinct bass modes (Room Tuning).
The trebble and bass level are adjustable in four different levels each.
Dimensions:
244 x 910 x 352 mm (Width x Height x Depth)
Rubber spikes +20mm
Weight: 27 kg/pc
Magnetically shielded: No
Impedance: 4-8 ohm
Binding post: Goldplated bi-wiring / Banana plug / Pole screw
Efficiency: 90dB
Power
* 550 W Short term IEC 268-5
* 200 W Short term IEC 268-5
Tweeter
Ribbon tweeter, SACD/DVD-Audio-ready, Sandvich ribbon cone in aluminium, neodymium magnets, chassis made in ceramic carbon steel.
Woofer / midrange
6,5" SEAS Excel, Magnesium driver, moulded "high flow" driver basket, powerful magnet,weight 1900 gram, shielded.
Woofer
6,5 "SEAS , coated paper driver, moulded high flow driver basket, powerful magnet,weight 1900gram.
Connections and settings
* Goldplated biwiring.
* Bassreflex, can be set to closed box (Room Tuning).
* The bass can be set to eight distinct modes using the supplied bass plugs
* The trebble level is adjustable in 4 different modes.
* The bass level is adjustable in 2 different modes.
Conditions :8/10
Color :Piano Black
Price :sold
Place :Perak
Construction type
Dimensions:
Rubber spikes +20mm
Weight: 27 kg/pc
Impedance: 4-8 ohm
Efficiency: 90dB
Power
Tweeter
Woofer / midrange
Woofer
- Number of posts : 1095
» Pioneer Floorstanding speaker and Center speaker
» NHT 2.5i Floorstanding Speaker (used)
» XTZ Floorstanding speaker
» AAD S-7 Floorstanding Speaker Used
