UPOCC Silver Gold Interconnect & Jumper
User Review
Using a 300B tube amplifier and the Harbeth Compact7 speaker.
KLEI Absolute RCA - Cable improves the Clarity, transparency and high note more extended. Sound seems bigger and bass also tighten. Mid is natural. I am very satisfied.
New User comment
1.5m pair Silver Gold interconnect cable with KLEI Absolute Harmony RCA Plug.
Cable is soft and flexible so easy to use than my current Stiff Cable.The cable improves the clarity, transparency and highs sound more extended. Sound stage seems bigger and bass also tighten. Mid is natural.
The cable has speed too.
A Very Goof Buy.
Customers' feedback
1) The impression is very sweet n smooth sounding n still got dynamic and speed.
2)I Just tried IC on the CD player. Find the bass is deeper and more natural sounding
Custom Silver Gold interconnect terminated with cryogenic treated KLEI pure Harmony Plug. (More than 10sets sold)
1 meter pair with KLEI Silver Harmony - SGD$410
with KLEI Pure Harmony - SGD$450
with KLEI Absolute Harmony - SGD$$499
1 meter pair SGD$470 with KLEI Pure Harmony RCA for Phono interconnect (Shielded version)
Great for solid state amplifier , the gold content in it provide extended bass. highs is refine and vocal timbre is
smooth. No harness at all.
Tube amplifier user - more high and refine extension.
The resultant cable is the epitome of low mass. A completed pair weights just 33 grams !
The KLEI Harmony plugs are the finest RCA plugs I've used. Solder lugs are easy to use, and the plastics used are far more rigid than the first generation Eichmann Bullet Plugs, which were designed by the principal of KLEI. The strain relief applies even pressure from opposite ends, which should allow the cable to sit squarely in the center of the barrel. The twisted pair of cables I used are very fine, so the strain relief doesn't do much here.
These cables perform to a much higher level than the Amtrans. There must be something special about the Silver / Gold wire used here. The Neotech is fast and open, and at the same time absolutely free from grain. It has a detailed midband, with outstanding high frequency extension.
The only thing I could have wished for is deeper bass extension. Although bass lines are well articulated and tight, it does not go as deep as some of my other cables.
If I were to put a price tag on these as a commercial product, I would put these on par performance wise with cables in the USD 1,000 to 1,500 range.
Speaker Jumper
It's 20gauge UPOCC silver gold jumper 150mm - Custom length @ SGD$160 for 4.
When use for jumper between High/mid to low. The separation is better and vocal timber
is nicer too.
Brands we carry
Auralic product (China)
Care Orchestra Designer Speaker (Italy)
Duelund cables and capacitors (Denmark)
ETI, KLEI RCA (Aus)
Fostex speaker (Japan),
German Hiend Cable (Germany)
Gyrotension Vega Isolator (Korea)
GML Speaker (Singapore)
Line magnetic tube amplifier (China)
Neotech cable (Taiwan)
Mundorf capacitors and cables (Germany)
Rockna DAC (Romania)
Psvane Tube ( China)
Full Music Tube ( China)
Custom Full Range Speaker boxes
Horn Box for various 15inch , or 12 inch driver
Robert 92383607 Whatsapp
Blk34 Upper Cross St
#02-152
New User comment
A Very Goof Buy.
Customers' feedback
Speaker Jumper
is nicer too.
Brands we carry
ETI, KLEI RCA (Aus)
#02-152
liveacoustics- New Member
- Number of posts : 24
Registration date : 2013-05-03
» Silver Gold OCC Interconnect
» Siltech G9 Classic Legend Coxial 380D (SOLD)
» 1.5 Meter RCA Mono Silver Crystal (UPOCC)
» Neotech Silver/Gold XLR Interconnect with Mylar Shielding. Dual Run in 1 meter [SOLD]
» Nanotec Systems MS208 RCA Interconnect with KLE Plug (Gold Silver Nano) (SOLD)
