Rogers 60th UK made edition LS35A mini monitor
New Shipment Arrival for 2015@ Musiclink
Introducing the world acclaimed ROGERS LS3-5A Monitor Speaker - 60th Anniversary Limited Edition(Made In England) + New Arrival AB-1 subwoofer system.
Model: LS3/5A 60th Anniversary Edition. (Made In England)
Retail Price@ $4500.00/pair. (Pls visit us for special price)
Model: AB-1 Subwoofer System.
Intro Price@ $1580.00/pair.(TEMPORARY NO STOCK)
Free Gift with every purchased!
Above featured photo is for 65th edition LS3-5A. Photo for illustration purposes only. Actual photo will feature 60th Edition which is similar in look with 65th edition.
Model: LS3/5A
System Type : Two-way infinite baffle (closed box)
Frequency Response : 70Hz - 20kHz +/- 3dB
Sensitivity : 83dB for 2.83V @1m
Bass / Midrange Driver : 138mm
Tweeter : 19mm
Crossover : Frequency 3kHz. Bi-wireable
Nominal Impedance : 11 ohm
Recommended Amplifier Range : 30-80 watt
Cabinet : 10mm Birch multi-ply. Critically damped
Grille : Black Tygan
Finish : Rosewood veneer
Model: AB-1 SUBWOOFER SYSTEM
This is a subwoofer system designed for use with the BBC LS 3/5a in either the 15 ohm or 12 ohm standard or bi-wire versions. The system increases low frequency performance, sensitivity and reduces overall impedance by presenting an easier load for the amplifier. Immediately after its launch, the AB-1 was awarded the prestigious '95 Las Vegas WCES Audio Exhibition Innovations Award. It is a cause for celebration!
System :Single way
Cabinet :High density particle board with MDF baffle
Responses :55Hz~120KHz +/- 3dB
Distortion :2nd & 3rd Harmonic less than 1% @90dB S.P.L (55KHz~20KHz)
Impedance :8 ohms
Sensitivity :82.5dB S.P.L
Max. Output @2m per pair :99dBA S.P.L
Bass / Midrange :Kef B110 125mm computer selected and graded
Bass / Midrange :N/A
Crossover :N/A
Recommended Amplifier Power :25~100 watts/channel
Reviews
Available Now@
MUSICLINK AV DISTRIBUTION
100 BEACH ROAD, #02-46-49
SHAW TOWER
SINGAPORE 189702
TEL: 62911106
BUSINESS HOURS: MON-SAT: 12.30-8PM DAILY. SUN & PUBLIC HOLIDAY: CLOSE.
musiclinkav- Dealer\Reseller\Trader\Service Provider
- Number of posts : 209
» Rogers LS3/5a 60th Anniversary Edition (used)
» Rogers LS35a 65th Aniversary monitor-sold
