Weiduka AC8.8 Power Purifier - Demo Unit SOLD
Weiduka AC8.8 Power Purifier - Demo Unit SOLD Empty Weiduka AC8.8 Power Purifier - Demo Unit SOLD
Post by raymond88 Fri Nov 27, 2015 2:31 pm
Item: Weiduka AC8.8 3000W 15A Advanced Audio Power Purifier
Condition: Demo unit in mint condition. Comes with power cord.
Price: SOLD or swap/topup
Weiduka AC8.8 Power Purifier - Demo Unit SOLD Weiduk10
Description:
 Weiduka AC8.8 uses the latest embedded square LCD header, making the machine more compact appearance, while avoiding the damage of the accidental collision of the header voltage directly reflects the intuitive. More detailed shell process is for the aluminum panel drawing process,making it look more stylish, bright. In all models has more excellence on the internal process, which is definitely your Hi-Fi and good partners.
This unit has use a unique and patented filter, breaking the traditional inductive filter components, can not only effectively eliminate the interference and noise in the power grid and to a minimum, and can make the music of the Hi-Fi, AV sound system signal transmission fasterthe low-frequency transient response of the music better, AV, Hi-Fi music, wide frequency response of the sense of hearing, the sound field level, and rich detail, coloration and low; in the visual system to listen to enhance its readingresolving capability of the better three-dimensional image layering, can reduce the color dye (color purity) to remove background noise pitting (to improve clarity), can get good results, so you get the perfect visual and audio effects!
Weiduka AC8.8 has 3000W strong load power, coupled with its dual inductor current filter can be easily driven by all kinds of HiFi, AV equipment, 27 to 50-inch color TV, three shots, projection, LCD rear projection, high-power amplifier, and a variety of theater equipment.
Features:
1.Use imported high quality components to make ​​of common mode and differential mode AC power filters, has surge surge absorption, the lightning current to overload the function of automatic circuit protection. Equipped Analog output of the professional instrument grade AC voltmeter, at any time direct the level of the filter output AC voltage 220V to audiophiles according to the level of the output voltage, the sound system tuned to the best audio and visual effects.
2.Filter materials used: the use of imported power cord, shielded metal hood fever-level German imports WIMA interference capacitor, the German the MKP professional pole filter capacitor.
3.15A automatic overload short-circuit protection
4.Six senior gold-plated universal socket (product insert), four high-quality imported American standard double reed socket.
5.Filter has 10 output sockets, each socket has a filter anti-interference function, the left of the five output receptacle separate switch control for the AV amplifier, integrated amplifier, PA power amplifier needs around the clock to burnor other purposes. The right side of the five output sockets another separate switch control available for a CD, DVD, LD, TUENR (coordinator), previous amp, AUX (auxiliary outlet) use. The output power is 3000W.
6.Use four American dedicated power outlet and six power outlet for multi-purpose, to meet different needs.
7.Use quality of high-purity copper wire, in order to reduce transmission losses and improve the speed of energy supply.
8.Professional-grade power outlet, thick copper, flexibility, close contact, effectively reduce the current reflection and loss of electric shock.This is also an important guarantee for good sound quality, and voltage LCD digital display table.
9.Quality capacitor filter, music soft and transparent, good sound field.
10.Use replacing power cord, you can always upgrade according to their own personality.
11.With lightning protection and overcurrent protection devices.Practical and safe.
Note: When the electrical equipment exceeds the rated 15A current, the overcurrent protection device automatically cut off the power socket; If you want to restart to power electrical equipment before unplugging, and then press the button to reset to look at over-current protection device.
Parameters:
Rated voltage: AC220V/50HZ
Maximum load power: 3000W
Maximum current: 15A
Size: 332mm * 132mm * 112mm
Weight: 2.4kg
Weiduka AC8.8 Power Purifier - Demo Unit SOLD Weiduk13
Weiduka AC8.8 Power Purifier - Demo Unit SOLD Weduka10
Weiduka AC8.8 Power Purifier - Demo Unit SOLD Weiduk14
Number of posts : 10093
