SUPRA cable
SUPRA cable
Made In Sweden
Length = 1 Meter
EFF-I
Analogue Interconnect Hi-Fi
Supra multi test winner! A reinforcement of even the finest details is the goal of all cable design. A traditional cable can, however, not achieve that quality, due to the construction. A good interconnect must have low capacitance and low skin-effect.
The skin-effect has a dynamic and noticeable influence because an audio signal is nothing but variations of frequencies and sound levels. If we were to transfer only one stable frequency the skin-effect would not be any problem. The frequencies push the signal differently far out from the centre of the conductor. High frequencies travel on the surface whereas low frequencies travel inside the conductor.
Thus, the higher the frequency, the higher the resistance.
In order to minimize the skin-effect the EFF-I is designed in accordance with Equalized Frequency Flow (EFF) Technique. It is based on tube shaped conductors with a wall thickness of 0.20mm, which is well below the smallest skin depth within the Audio range. This allows the same resistance for all frequencies. The result is a transparent and exact reinforcement with clear room definition.
EFF-I One of SUPRA´s most awarded products, not without good reason... EFF-I
Configuration
EFF-I
Analogue connection, for instance from CD or pre-amp to amplifier.
Supra Swift XLR Au Set XLR Male and Female
1 XLR Female / 1 XLR Male
XLR connector with 24K gold plated pins.
Fully shielded for noise rejection.
If you plan to move your audio/video devices to the next level
The right cable can bring a massive improvement in every music range.
You will be able to hear new, undiscovered sounds in your favourite tracks and delight in it as when you hearing it for a very first time.
We treat audio video cables like link to emotions, not like a piece of cord.
We follow only for the highest quality products, not always the cheapest but always the best.
So we would like to present Swedish audiophile interconnect - Supra EFF-I terminated in best quality SUPRA SWIFT XLR connectors with gold plated contacts,
That means the performance that you buying is worth every penny spent.
Last edited by HiFiLab on Mon Jan 21, 2019 6:07 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
BUMP
UP
BUMP
UP
BUMP
Up
» Supra LoRad 2.5 Main Cable Power Cable (sold)
» Supra USB 2.0 Cable Type A-B USB Cable- 2m (Used) SOLD
» Supra AES/EBU cable
» Supra EFF-I XLR cable (Used) - SOLD
» brik dac with supra usb cable
