Rel T3 Subwoofer
Rel T3 Subwoofer Empty Rel T3 Subwoofer
Post by Richard@yew Fri Apr 01, 2016 8:26 am
Rel T3 Subwoofer T3seri10
Subwoofer T3
Connections: Neutrik Speakon high-level, line-level, LFE with separate volume control
Enclosure Type: Passive radiator
Woofer (size in inches, type): 8 active (1), composite cone, 8 passive (1), composite cone
Power Rating (watts): 150
Crossover Bypass: Yes
Available Finishes: Cherry, Black, White
Dimensions (H x W x D, inches): 13.75 x 11.2 x 14
Weight (pounds): 27
The T3's close-miked response, normalized to the level at 80 Hz, indicates that the lower –3-dB point is at 30 Hz and the –6-dB point is at 27 Hz. The upper –3-dB point is at 97 Hz using the LFE input.—MJP
REL T3 Subwoofer
Build Quality: Build Quality 93 Good
• Finished solid-maple side rails
• Crossover and volume controls with detents
Value: 96 Excellent
• High-end audio performance at a budget price
• Stylish and compact design
Features: 93 Good
• Separate volume controls for speaker-level and LFE inputs
• Neutrik Speakon high-level connector
Performance: 94 Good
• Established a bass underpinning for the system
• Created bass output with texture and nuance
Ergonomics: 90 Good
• Small cabinet size and forward-firing passive and down-firing active provide more placement options
• Side cabinet rails are convenient for lifting
Selling Price : RM2,550 ( Call For Best Price )
Richard Yew (+016-6217099)
pls: whatsapp/sms
CMY Audio & Visual S/B
LG2.13,LOWER GROUND LEVEL2,SUNWAY PYRAMID SHOPPING MALL,
NO3,JALAN PJS 11/15,BANDAR SUNWAY,
46100,PETALING JAYA,SELANGOR,
MALAYSIA.
Richard@yew
Number of posts : 228
Registration date : 2016-03-30
