Various Interconnects: Abbey Road Cables, Anti-Cable, Van Den Hul, Audioquest, MIT, Pure Sonic, etc
Item: Abbey Road Cables Monitor Interconnects - 1m pair
Condition: 8.5/10. Item is in excellent condition.
Price: RM690 or swap/topup
All EMI Abbey Road Studios are wired with Abbey Road Cable - Your music was made with these cables!
In association with EMI Abbey Road Studios, Moving Air Limited has produced ground-breaking results in cable technology.
Using scientific principles and advice from some of the best engineers in the business Abbey Road has studied how cable affects the audio signal. Armed with those findings Abbey Road then set about producing what many believe is the best audio cable around.
Whether it is music production, film sound, or album mix; when you buy into Abbey Road Cable you are buying into authentic sound. Abbey Road Cables have really gone to the technological limits to get an astounding result. That result is a cable that works as if there is no cable at all. That means to have a cable that, in audio terms, is absolutely neutral, one that is truly transparent.
Abbey Road Cables is about your hi-fi sounding authentic. With Abbey Road Cable you know that at the heart of your system is the experience of BAFTA nominated dubbing mixer Dan Gable and the expertise of leading studio designer Michael Whiteside. And behind Abbey Road Cable is the confidence and unique experience of EMI Abbey Road's engineers, unparallel in professional recording.
Abbey Road Cables Monitor Interconnect:
The screen-free aspect of the Abbey Road Cables Monitor interconnect cable means it has very low capacitance. It gives one of the best listening experiences compared to other cables of several times more cost. This reflects Abbey Road Cable's design focus toward achieving a phase coherent response.
Technical evolution:
The phase coherency of in-audible ultra-sonic components of sound dramatically affects how we hear hear the audiobile frequencies. Getting things to work well above the audio spectrum was the key to achieving a fast and relaxed, natural sound.
Dielectrics:
Having a fast cable is one thing; having it with consistent electrical properties is another. With our unique twin dielectric system we have achieved both. All dielectrics have an electrical 'absorbency' and act like a 'sponge' slowing down the audio signal. Our gas foamed polyethylene primary dielectric reduces this. A secondary dielectric of solid polyethylene gives low and consistent capacitance. The twin dielectrics work together to give both speed and accuracy.
Cable with a twist:
Abbey Road Cable’s characteristic starquad and pair twist has a purpose. Potential electromagnetic waves meet equal areas of positive and negative conductors causing them to cancel out the interference by phase reversal. This type of noise rejection does not use a screen. Without a screen, capacitance is reduced significantly. Capacitance affects imagery and muddies the signal. In short the less capacitance the better. We think it looks great too.
Conductors:
Our study of electromagnetic fields in cables led to the development of our ultra fine stranded silver-OFC hybrid conductor. Constructed to eliminate the usual parasitics of stranding, this conductor gives linear phase response across the full audio spectrum and beyond. Phase linearity and dielectric neutrality are the essentials behind the natural staging of Abbey Road Cable.
Specifications:
Conductors: 4 x 28/0.1 high purity, oxygen free copper
Primary dielectric layer: Olefinic/nitrogen foamed primary
Second dielectric layer: Solid polyethylene secondary skin
Lay: Orbital twist, 100mm lay lenght
Capacitance (min) 33pF/m, 11.3pF/ft
Resistance (starquad format) 0.037 ohms/m, 0.012 ohms/ft
Overall jacket Crystal clear PVC
Overall diameter 6.0mm/0.24 inch
Length: 1.0 M
http://www.elusivedisc.com/ABBEY-ROAD-CABLES-MONITOR-INTERCONNECT-RCA-10M/productinfo/ARCIM1R/
https://www.thecableco.com/Product/Monitor
Item: Anti Cable Level 3.2 Reference Interconnect - 1m
Condition: 8.5/10. Item in excellent condition, near mint.
Price: sold
Got 2 pairs for sale
Some info:
The ANTICABLES Analog RCA Interconnects use the same design concept as the award winning ANTICABLES Speaker Wires. They use only the materials needed (solid core wire and connectors). Those materials are of very high sonic quality, and unnecessary materials such as thick plastic jacketing are eliminated. They are simple, cost effective, and perform very very well
Testimonials:
http://anticables.com/testimonials/analog-interconnects-testimonials
Level 3.2 "Reference Series" Analog RCA Interconnects: A stereo pair of Anti-Cable Interconnects which will enable line level analog connections between components.
The Level 3.2 interconnect use Anti-Cables new and better sounding Silver/Gold alloy signal wire which replaces the original Level 3's 100% silver wire. Adding a small amount of Gold eliminates the sonic signature of Silver, leaving only the music to be heard. The price has been kept the same, but the performance is greater.
The Level 3.2 also incorporates the newly available and better sounding Keith Louis Eichmann Copper Harmony plugs, which outperform his original Bullet plugs.
Highlights:
Sound Improvements over Level 2.2 Performance Series:
Sound Improvements over former Level 3 versions:
Additional Features:
Upgrade Paths:
Design Concept:
Typical interconnect cables usually have a signal wire surrounded with a thick plastic dielectric material, which is then surrounded by the ground conductor to shield it from EMI/RFI noise, and then more plastic dielectric material. This typical approach has the usual drawbacks of accumulating a lot of dielectric effect distortion, and an accumulation of shunting capacitance. The Anti-Cable Analog RCA Interconnects use a different approach. Since air is a near perfect dielectric, no extra insulation dielectric material (beyond the thin red coating) is used, and the wires are suspended in free air. Eliminating dielectric effect distortion is what allows these interconnects to sound like music, (not a cable).
http://anticables.com/interconnects/analog-rca-interconnects#!/Level-3-2-Reference-Series-RCA-Analog-Interconnects/p/14644593/category=3682626
https://www.divineaudio.co.uk/anti-cables-level-3-2-reference-series-rca-analog-interconnect-1m
Item: Van Den Hul D310 MkII Interconnect - 1m pair
Condition: 8/10. Item in very good condition
Price: RM550 or swap/topup
Some Info:
The massive D - 310 Mk II’s design is primarily based upon our former D - 300 S; yet further improvements like a lower capacitance, better propagation properties and a higher flexibility have been implemented.
This coaxial cable’s core consists of 19 Matched Crystal (MC) OFC strands with a very dense and very pure silver coating.
The resistance of the core is: 1.10 Ohm/100 meter.
The resistance of the shielding is: 0.20 Ohm/100 meter.
Latter very low value prevents hum problems in complex grounding situations.
The inner 7.25 mm. diameter insulation is made of polyethylene foam with Nitrogen as filler.
The result is a very low capacitance of 56 pF/meter.
The Nitrogen also provides a very good protection against oxidation.
The outer shielding is braided in 2 layers with a total of 432 Matched Crystal (MC) OFC wires with a dense and very pure silver coating.
The D - 310 Mk II’s outer jacket is made of tan-metallic coloured HULLIFLEX ® with an external diameter of 11 mm.
The D - 310 Mk II can be used as massive interlink of extreme high quality between preamps. and power amps. Also as a speakerline this cable will perform extremely well. When internal wire and shielding are soldered together the total resistance is a very low: 1.7 Ohm/km.
The main purpose of the D - 310 Mk II however is the application in Home Theatre setups as a very good and stable 75 Ohm video cable.
For single-ended audio interlink purposes our high quality 11.3 mm. RCA type connector C - 11.3 is available.
http://www.solidstate-audio.com/index.php?main_page=product_info&products_id=6759
Item: AudioQuest Turquoise 2 interconnects - 1m
Condition: 7/10
Price: RM230 or swap with your cables
Contact: 012-3816611 Raymond
Item: MIT Terminator 5 RCA Interconnect - 2m
Condition: 8/10. Item in very good working condition
Price: RM380 or swap/topup
Item: MIT Terminator 4 RCA Interconnect - 1m
Condition: 8/10. Item in very good condition.
Price: RM350 or swap/topup
Item: Pure Sonic RCA Interconnect - 1m
Price: RM230
Item: Audioquest Copperhead Interconnect - 1.5m
Condition: 8.5/10
Price: RM190
Item: Audioquest Diamondback Interconnect - 1m
Condition: 8/10. Item in good working condition
Thank you.
Dielectrics:
Cable with a twist:
Conductors:
Specifications:
Length: 1.0 M
Price: sold
Some info:
Testimonials:
Highlights:
- Keith Louis EIchmann Copper Harmony RCA Plugs
- Silver/Gold alloy signal conductors
- More resolving of textural and tactile information
- They allow you to hear not just the musical instruments, but also how they are being played
- Greater resolution also provides a bigger and deeper soundstage
- The sonic signature of 100% silver wire is now removed
- The highs no longer sound a bit "hard", "forward", or "bright"
- Highs remain naturally "soft" and deep in the soundstage where they belong
- More resolving of musical information makes music more involving
- No thick plastic jacketing, which adds dielectric effect distortion and smears the audio signal
- Double shielded option is available for use with turntables or when extra RFI/EMI protection may be needed.
- Sound less like a cable and more like real music than cables costing many times more
Upgrade Paths:
- The Level 4.2 "Reference PLUS" Analog RCA Interconnects, also utilizes the new Silver/Gold alloy conductors which are more resolving of textural and tactual information, "plus" the new Silver Harmony plugs which are more resolving.
- The Level 5.2 "PURE Reference" Analog RCA Interconnects, also continues to utilizes the excellent new Silver/Gold alloy signal wire, but also adds the worlds best sounding PURE Harmony RCA plugs
Design Concept:
Some Info:
Condition: 7/10
Price: RM230
Condition: 8.5/10
Price: RM190
Thank you.
» Various Interconnects: MIT, Taralabs, WireWorld, Anti Cables, Abbey Road, Kimber Kables
» Abbey Road Cables Monitor Interconnects - 2m pair
» Paul Speltz Anti Cables and Anti-Interconnects (SOLD)
» Anti-Cable speaker cables [used]-sold
