N.E.A.R New England Audio Resource 10M Bookshelf Speakers
RARE
Made In USA
N.E.A.R, an acronym for New England Audio Resource
Description :
The Near 10M Loudspeaker's bass and output capabilities are very impressive. Suitable for small room as it will not occupy that much room.
Specifications :
Drivers...............................................One 1" titanium inverted dome tweeter
................................................One 5 1/2" Mid-range Driver
Frequecy response.............................48Hz to 21kHz (± 2 dB)
Sensitivity..........................................88 dB/w/m (4 Ohms)
Weight...............................................8 kg
Dimensions(w x d x h).........................18.5 x 25.5 x 28 cm
N.E.A.R 10M Bookshelf Speakers
This is diminutive little powerhouses Speaker
they are fantastic,you will be amazed at the size of the sound that comes out of the small boxes.
Some may feel that metal drivers have a harsh sound. Not true with the NEAR 10M. Very smooth. I'm sure lots of viscous ferro fluid in the mid/bass voice coil helps to tame resonances. The tweeter is very smooth and non-fatiguing.
Properly set up, they simply disappeared in the MUSIC and all the listener is left with is glorious music with a wide, tall ,clarity and great deep soundstage.
I would argue that you would be hard pressed to find better sounding speakers at five times this price.
Come give them a listen.
If you don't know these speakers,
I see the NEAR 10M as being perfectly suited for the music lover who doesn't want to or can't sacrifice a lot of room for speakers
The NEAR speakers are very well balanced, without any glaring weakness, even with less expensive gear.
The bass goes as deep as any speaker in this price range, even if the enclosure is very small.
Price : RM 1350
Please click below link to view more hi fi item for sale:
https://carousell.com/hifilab
Last edited by HiFiLab on Mon Apr 25, 2016 10:43 am; edited 1 time in total (Reason for editing : correction)
- Number of posts : 2967
» Wharfedale England Bookshelf Speakers 506
» Harbeth M40.3 XD Bookshelf Speakers Made In England
» ATC SCM7 Bookshelf Speakers Made In England
» ATC SCM11 Bookshelf Speakers Made In England (PL) ( Sold Out )
