[SOLD] Pioneer A-A6 audiophile stereo amplifier
This is a rare find and excellently reviewed amp:
1. http://www.whathifi.com/pioneer/a6/review
2. http://www.goodgearguide.com.au/review/pioneer/a6/220021/
The A-A6 features AIR Studios tuning; engineers have put this amplifier through rigorous tuning, determined to deliver audio output that is as pure and precise to the original as possible.
The A-A6 is built integrating class-AB Dual Mono symmetrical amps (which operate in pure class-A mode in low power, eliminating switching and crossover distortion).
This amplifier is equipped with gold plated terminals, including headphone output, and feature a Source Direct mode to avoid any sound signal interference.
• Continuous power output (both channels
driven at 20 Hz to 20 kHz)**
THD 0.2 % . . . . . . . . . . . . . . . . . . . . . 60 W + 60 W
THD 0.2 % . . . . . . . . . . . . . . . . . . . . . 45 W + 45 W
• DIN Continuous power output (both
channels driven at 1 kHz)
THD 0.7 %, 4 Ω . . . . . . . . . . . . . . . . . 70 W + 70 W
THD 0.7 %, 8 Ω . . . . . . . . . . . . . . . . . 47 W + 47 W
• Total harmonic distortion**
20 Hz to 20 kHz, 25 W, 8 Ω. . . . . . . . . . . . 0.05 %*
* Measured with DIRECT button switched on.
** Measured by Audio Spectrum Analyzer
Audio section
• Input (Sensitivity/Impedance)
CD, TAPE, TUNER, AUX . . . . . . . . . 200 mV/47 kΩ
PHONO (MM) . . . . . . . . . . . . . . . . . .2.8 mV/47 kΩ
• Frequency response
CD, TAPE, TUNER, AUX . . . . 5 Hz to 100 kHz dB
PHONO (MM) . . . . . . . . 20 Hz to 20 kHz ±0.2 dB
• PHONO (MM) overload level
1 kHz, THD 0.2 %. . . . . . . . . . . . . . . . . . . . . . 60 mV
• Output (Level/Impedance)
TAPE REC . . . . . . . . . . . . . . . . . . . . . 200 mV/1 kΩ
• Tone control
Bass . . . . . . . . . . . . . . . . . . . . . . .± 10 dB (100 Hz)
Treble . . . . . . . . . . . . . . . . . . . . . .± 10 dB (10 kHz)
• Signal-to-Noise Ratio
CD, TAPE, TUNER, AUX (200 mV input) . . 103 dB
PHONO (MM, 2.8 mV input) . . . . . . . . . . . . 80 dB
• Signal-to-Noise Ratio (DIN, continuous
power/50 mW)
CD, TAPE, TUNER, AUX . . . . . . . . . . .91 dB/65 dB
PHONO (MM, 5 mV input) . . . . . . . . .68 dB/60 dB
Miscellaneous
Power requirements . . . . . . . .AC 220 – 230 V, 50 / 60 Hz
Power consumption . . . . . . . . . . . . . . . . . . 170 W
In standby. . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 W
Dimensions. . . . 420 mm (W) x 100 mm (H) x 359 mm (D)
Weight (without package). . . . . . . . . . . . . . . 10 kg
Letting go at RM1,200 negotiable. Please call Wang - 012 3344 01 nine. Thanks. WhatsApp for pics please.
Audio section
• Tone control
power/50 mW)
Miscellaneous
Last edited by providenceprops on Wed May 25, 2016 4:12 pm; edited 1 time in total
providenceprops- Regular
- Number of posts : 94
Registration date : 2015-09-08
Re: [SOLD] Pioneer A-A6 audiophile stereo amplifier
Bumped with discount! Thanks. Sweet amp, what're you waiting for?
» Pioneer A 400 X stereo amplifier (used )SOLD
» Pioneer AK-90 Stereo Mixing Amplifier (Used) SOLD
» Pioneer SA-8900 II stereo amplifier (used) SOLD
» Pioneer A-717 Reference stereo amplifier (sold)
» Pioneer SA-708 Stereo Integrated Amplifier (Sold)
