LITE audio P100 power regenerator
2 posters
LITE AUIDO P100 POWER REGENERATOR
P100 is a Hi-End power regenerator mainly for audio equipment with power consumption less than 100W. Its voltage (100 to 240V) and frequency (50hz, 60hz to 400hz) can be adjusted by press of button.
The special design for this power regenerator is converting the AC input to DC then converting to AC ouput. This design mainly reduce the high frequency noise, reduce the AC side noise that makes a clear background. After using it, the bass will become strong, high frequency noise disappear and more details come out!
Advantage :
1. isolates the effects of voltage fluctuations
2. Reduces glare and harshness
3. Better detail and texture information
4. improve soundstage and imaging
Specification:
- AC Input: 230V/50Hz
- AC Ouput: 100V ~ 240V selectable with 2V per step
- Frequency adjustable: 50Hz, 60Hz, 120Hz, 400Hz (selectable)
- LED display for Voltage/Frequency
- AC output socket: IEC x 2
- Output power: 100W continous, 400W peak
- Over heat protection, unstable voltage cut circuit
- Voltage stable: <0.5%
- THD: <0.03%
- Dimension: 433mm(W) x 322mm(D) x 99mm(H)
- Weight: 10.5kg
- Very good for LP and source, CD,DAC
Price : RM sold
Contact : 016-3733907
Advantage :
Specification:
- THD: <0.03%
- Weight: 10.5kg
Price : RM sold
seanlock85- Frequent Contributor
- Number of posts : 244
Registration date : 2015-08-06
Re: LITE audio P100 power regenerator
35 posts, time to read the rules of the forum friend. Kindly do not use all caps in your title. This is deemed rude internet behaviour, called 'shouting.' Do edit your title, and oh, now would be a great time to read the forum rules.
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
» Lite P100 AC Regenerator (Sold)
» Ps Audio P10 Power Regenerator
» Ps audio Power Plant Primer Power regenerator (SOLD)
» PS Audio P10 Power Regenerator(Sold)
» PS AUDIO - P10 Power Plant - Power Regenerator (Sold)
