B&O Icepower 125W & 50W stereo power amp (new)
- ORIGINAL module from B&O - while stock lasts!
- fully integrated, intelligent audio power conversion solution designed particularly for highly competitive consumer and professional audio products.
- protected against short-circuit, overload and over-heating and includes onboard fuses and EMI filtering to provide a CE and FCC pre-approved design.
This exact module is used in Jeff Rowland 102 power amp:
ICE125ASX2 Stereo Power Amp - U$450 / RM1790
- 125W x2 @ 4 Ohm, Single Ended
- THD+N 0.003%
- Maximum current draw 30A, minimum load 3 Ohm (SE)
- 16cm x 8cm (module size)
- Fully built with power switch, speaker binding posts, RCA sockets, IEC
ICE50ASX2 Stereo Power Amp - U$350 / RM1390
- 50W x2 @ 4 Ohm, Single Ended
- THD+N 0.003%
- Maximum current draw 20A, minimum load 2 Ohm (SE)
- 11cm x 8cm (module size)
PM or email us for more details.
Icepower 125ASX2 |
Icepower 125ASX2 power amplifier |
Icepower 125ASX2 Power Amp |
Icepower 50ASX2 |
Icepower 50ASX2 Power Amp Module |
Icepower 50ASX2 Power Amplifier |
Notes:
- Upgrades available - better casing, upgrade to WBT / Furutech speaker binding posts / RCA connectors, Furutech / IEGO IEC power connectors, Furutech / Mundorf / PCOCC internal wiring
- Lead time - ~2-3 weeks
Details of the Icepower modules can be found here:
- [You must be registered and logged in to see this link.]
Reviews
» Icepower amplifier module monoblock/stereo SOLD
» Roksan Kandy K2 Power Amplifier - 125W@8 Ohms
» Icepower Amplifier
» M&K V125 Subwoofer 12inch driver, 125W, 20-200Hz
» Sim Audio W2002 125w per chanel Made in Canada
