Primare I21 Integrated Amplifier (Display Unit)
The I21 is a compact amplifier designed to produce the current necessary to drive demanding loudspeaker loads for greater fidelity. A healthy 75 watts per channel is generated by a massive 800VA toroidal transformer, which, being consistent with Primare’s dual-mono design philosophy, has separate windings for left and right channels. To keep the power clean as well as prodigious, the driver and preamp stages - and even the supply to the front panel - are individually regulated in seven steps.
Inputs :
4: Unbalanced Stereo - RCA
Outputs :
1: Unbalanced Record Output - Stereo RCA, 1: Unbalanced Preamp Output - Stereo RCA
Output Power :
75 Watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, Both Channels Driven.
125 Watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, Both Channels Driven
Mode of Operation :
Dual Mono Construction:
Totally Independent Power Supplies (1 Per Channel)
Current Capacity 25 Amperes Peak Per Channel
Frequency response :
<10 Hz-100 kHz, -3 dB.
Selling Price :
Offer Price : RM4,300.00 (Limited Stock Only!!)
Steve Chua (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Tel : +603-7726 6893
Fax : +603-7726 6893
» Primare I-21 Integrated Amplifier (Display Unit)
» Primare I-22 Integrated Amplifier (Display Unit)
» Primare - I21 Integrated Amp ( Display Unit )
» Primare CD-22 (Display Unit)
