Epos M5 with Epos ST35 speaker stand
Epos M5 with Epos ST35 speaker stand Empty Epos M5 with Epos ST35 speaker stand
Post by Baracuda Fri Nov 18, 2016 8:50 pm
EPOS M5
Description: Two-way shielded, biwirable, reflex-loaded, stand-mounted loudspeaker. Drive-units: 1" (25mm) dome tweeter with gold-anodized aluminum-alloy diaphragm, 5.4" (137.5mm) mineral-loaded polymer-cone woofer. Frequency range: 60Hz–20kHz. Impedance: 4 ohm nominal. Sensitivity: 87dB/W/m. Power handling: 100W. Recommended amplification: 25–100W.
Dimensions: 12.7" (325mm) H by 6.8" (174mm) W by 8.2" (210mm) D. Weight: 12.3 lbs (5.6kg)
Read more at http://www.stereophile.com/content/epos-m5-loudspeaker-specifications#fvteXsG52ZSm6SR0.97
EPOS ST35 Speaker Stand
Designed initially to accommodate the ELS3, the ES35 metal stand is both elegant and functional. Supplied in a black finish and will also be suitable for the new Epos M5 speaker.
It stands 56cm high (without spikes) and has a solid top plate. The bottom plate features an Epos badge. Three columns make up the supports, the larger of which has the added advantage of a cable channel.
This particular model does not have provision for the addition of sand fill. The stands are supplied in a self assembly format complete with top and bottom spikes.
https://www.stoneaudio.co.uk/?product=epos+st35+speaker+stands
Condition 9/10
Price : RM 1850
Wassup : 01115440600 for pitcure
Baracuda
Number of posts : 8
Registration date : 2016-10-03
