Passive Filter (GC303) Power Distributor 6 output
2 posters
Star connection reduce interference between receptacle and ground
GC303 Making
Size: 348mm x52mm x86mm
Chassis Thick: 12mm
IEC: Acrolink Fi06(Gold)
Socket: Cooper IG8300 (with cryo -196 treat)
Internal Cable: 10awg neotech 7n upocc copper, 5n silver 20awg
Connection type: Star Connection
Cone: 4 Brass copper spike isolation cone feet and base
Filter: GC303
GC303 is a special material bonds to the interior bottom-plate of the chassis and cables that absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The power distributor uses no filtering besides GC303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components.
Ingredients of GC303:
Graphene, Green carborundum, Tourmaline powder, natural quartz powder and others non-magnetism things.
Graphene Introductions:
http://www.nanowerk.com/spotlight/spotid=27088.php
Most of power supply box uses series type noise filter.
But series type filter transfers noise elements to heat by magnet which not only absorbs noise, it also absorbs important electrical energy.
Also the magnetic body produces magnetic distortion by the noise absorption which adds a distorted feel and thinness to the sound.
This is because an electromagnetic wave absorbent material itself is a strong magnetic body.
Also parallel type noise filter or choke coil can not avoid loss in transmission energy.
It eliminates noise buy it takes away feeling of restraint and energy feel from the sound.
Green carborundum has no side effects because it non-magnetic body.
It only absorbs electromagnetic wave noise which is produced from receptacles and internal wiring.
Green carborundum is the only electromagnetic wave absorbent material which improves sound quality and S/N ratio.
Also the Tourmaline powder releases negative ion and keep the amount static electricity very low.
The natural quartz powder releases far infrared rays which has an surface activation effect. This leads to very realistic and sound filled with a feeling of throbbing pulse.
Warranty: no limit, as long as the damages are not due to misuse and unauthorized modification.
Return Policy: 1 week. Buyers are enjoying 1 week free return with full refund (excluded postage)
Price: RM980
Contact: Loke 0163733907
seanlock85- Frequent Contributor
- Number of posts : 244
Registration date : 2015-08-06
Re: Passive Filter (GC303) Power Distributor 6 output
after 2 year owning your power strip....still super satisfied...good stuffs
edmundchan86- Regular
- Number of posts : 71
Registration date : 2015-01-12
» MS HD Power MS-E02S Rhodium Power Filter Distributor(SOLD)
» Audio-GD Power Filter Distributor (sold)
» Furutech E-TP80 AC Power Filter Distributor
» Furutech e-TP80 AC Power Filter Distributor (SOLD)
» Xindak XF-1000 Power Distributor with Filter (SOLD)
