Mirage MM-6 Ultra-compact Powered Subwoofer
Item: Mirage MM-6 Ultra-compact Powered Subwoofer
Condition: 8.5/10. Item in excellent condition. No scratches or dents.
Price: sold
Actual pic of item in use:
Our smallest powered subwoofer to date, the MM-6 packs intense, full-bodied bass into a miniature 8-inch cube that fills your room with magnificent sound.
In order to achieve dynamic home theater and music listening experiences, there's no question: you need a subwoofer. And, while you'll feel its thunderous bass, the MM-6 won't steal it away from your decor; as it neatly tucks away under a table or in a
http://www.miragespeakers.com/subwoofers/?sku=MM-6
http://www.crutchfield.com/S-NJZiEHm13qb/p_653MM6/Mirage-MM-6.html
See my other stuffs here:
https://carousell.com/raymondhifi/
Price: sold
Sleek little cube blends perfectly with any décor
- High-gloss black finish hand-sanded to perfection
- Neatly tucks away under a table or in a corner
- 6.5-inch woofer and dual passive radiators deliver powerful deep bass
- Ribbed Elliptical Surround technology provides true depth without
Marvelously Miniature
corner.
The MM-6's exceptional looking cabinet is constructed of rigid medium density fiberboard and finished in a furniture-grade high-gloss black, achieved via seven layers of hand-sanded polyurethane. Inside, the MM-6 packs premium materials and advanced technologies that let you experience the full impact of your music and movies.
Pair the MM-6 with the immersive sound of any of our other speakers and experience home audio entertainment like never before.
[b][b][b][b]System Type[/b][/b][/b][/b] | Single active, dual passive | |
[b][b][b][b]Variable Low Pass Filter[/b][/b][/b][/b] | 50Hz-200Hz, Bypass | |
[b][b][b][b]Variable Phase Control[/b][/b][/b][/b] | 0 degrees - 360 degrees | |
[b][b][b][b]Weight (Kg/lb)[/b][/b][/b][/b] | 10.1 lbs (4.6 kg) | |
[b][b][b][b]Power Mode Switch[/b][/b][/b][/b] | Off/auto/on | |
[b][b][b][b]Inputs[/b][/b][/b][/b] | L + R Line in/Sub in | |
[b][b][b][b]Product Finish[/b][/b][/b][/b] | High gloss black | |
[b][b][b][b]Frequency Response (Hz, +/-3dB)[/b][/b][/b][/b] | 42Hz-200Hz | |
[b][b][b][b]Part Number[/b][/b][/b][/b] | 1009510 | |
[b][b][b][b]Overall Dimensions (mm/in, HxWxD)[/b][/b][/b][/b] | HxWxD, 8 x 8 x 8 inches , 20 x 20 x 20 cm | |
[b][b][b][b]Woofer[/b][/b][/b][/b] | Active: 6.5-inch (16.5 cm) Black anodized aluminum cone with inverted Ribbed Elliptical Surround, Passive: 2 x 6.5-inch (16.5 cm) Black anodized aluminum cones with inverted Ribbed Elliptical Surround | |
[b][b][b][b]Amplifier Power Output[/b][/b][/b][/b] | 800 Watts | |
[b][b][b][b]Max SPL[/b][/b][/b][/b] | 97dB @ 30Hz, ground plane, 1m | |
[b][b][b][b]UPC[/b][/b][/b][/b] | 629303-40025-8 |
» Mirage ps-12 subwoofer
» SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
» SOLD SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
» Dali Spektor 1 Ultra Compact Speaker
