SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
Item: SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.
Price: RM6300 or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
Add powerful bass to your home entertainment experience with the piano gloss black SVS SB13-Ultra 13.5" 1000W Subwoofer. It uses a 13.5" front-firing woofer to produce up to 1000W of RMS power and up to 3600W of peak power for ground-shaking performance in nearly any listening environment. With a frequency response of 20 to 460 Hz, the SB13-Ultra is equipped to handle virtually all types of listening material.
Front-firing 13.5" driver
Protective non-resonant steel mesh grille
MDF (Medium-Density Fiberboard) cabinet enhances rigidity
Detachable power cord
13.5" Ultra-series driver optimized for sealed applications
Die-cast aluminum basket
Flat-wire, 3" diameter, 8-layer aluminum voice coil
Polyimide-impregnated fiberglass former/bobbin
Dual 9", composite-layered, linear-roll, high-excursion spiders
Integrated tinsel leads
Nickel-plated spring terminals
Injection-molded gasket and parabolic SBR enhanced-excursion surround
Composite pulp/fiberglass press-layered cone with stitched surround
Low-carbon 1008 steel components and electrophoresis black plating
FEA-optimized overhung motor structure with a custom gap extension plate designed to enhance force/displacement symmetry, lower distortion, and increase linear stroke
Copper shorting sleeve reduces gap induction and distortion and enhances thermal conductivity
Dual Genox 8H/Y-35 ferrite magnets
Oversized pole vent for improved cooling and reduced noise
1000W RMS continuous, 3600W peak dynamic power
Class D topology designed for efficiency and cool-running
Detachable power cord with a main power switch and ceramic fuse
RoHS compliant, lead-free construction, and worldwide safety certifications
Auto-On / On switch with "green" standby mode
Stereo line-level RCA and balanced XLR input/output connections
Normal and Hi input voltage switch
Fully adjustable (frequency and slope) phase-correct speaker/sub digital crossover
EQ and DSP limiter settings
IFC (Intelligent Feature Control) with an LCD display
Two digital PEQs with adjustable frequency, cut/boost, and Q values
Room gain compensation control with adjustable frequency and slope
Adjustable digital delay on main speaker line-level outputs to time-align the speakers and subs
https://www.svsound.com/products/sb13-ultra
https://www.hifix.co.uk/svs-sb13-ultra-subwoofer
https://www.soundandvision.com/content/svs-sb13-ultra-subwoofer
Subwoofer Features
Driver Features
Amplifier Features
» SOLD SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
» Sumiko S.9 Subwoofer by Sonus Faber- Gloss Piano Black
» SVS SB13-Plus active sealed subwoofer (used)
» SVS SB13-Ultra Subwoofer (Used)
» SVS SB13-Ultra Subwoofer ( sold )
