Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair)
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Empty Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair)
Post by raymond88 Wed Aug 09, 2017 12:10 am
Item:  Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) With matching external power supply unit.
Condition: Item in very good working condition. Have been throughly serviced by Mr Oh few months ago. Also in very good physical condition with no dents or scratches.
Price: RM2800 or swap/topup
Description
The Meridian 105 is a high quality, high fidelity, self powered mono amplifier for use in musical applications - the newest amplifier in the Boothroyd Stuart Meridian range, it uses highly developed electronics to produce outstanding performance of power, stability and inner detail of sound.
The amplifier is presented in a mono format, each channel being a separate self-powered section delivering 100W minimum which can be purchased separately for driving a sub-woofer, or in pairs for normal stereo installations.
It is possible with the mono arrangement to locate each power section very close to its loudspeaker with improved results due to short 'speaker cables.
It is of course ideally matched to the 101/101MC Control Units.
Power output: 100W into 8Ω (mono)
Total harmonic distortion: 0.1%
Input sensitivity: 0.775V
Signal to noise ratio: 90dB
Dimensions: 283 x 52 x 300mm
Weight: 6kg each
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Meridi10
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Meridi12
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Meridi11
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Meridi13
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Meridi14
Websites:
http://www.meridian-audio.info/public/100_series_review_(hi-fi_news_-_sept_2005)%5B460%5D.pdf
https://www.hifiengine.com/manual_library/meridian/105.shtml
http://www.pearl-hifi.com/06_Lit_Archive/15_Mfrs_Publications/Meridian/Meridian_101_Preamp.pdf
http://www.ciao.co.uk/Meridian_105__Review_5799488
Number of posts : 10037
 Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair) Empty Re: Boothroyd Stuart Meridian 105 Monoblock Power Amplifier (1 Pair)
Post by raymond88 Tue Aug 15, 2017 4:47 pm
