AR(Acoustic Research) Integrated Amplifier (used)
Int
Integrated amplifier
made in USA
Condition:7/10
The solid-state Integrated Amplifier of AR
In the test report of the
February, 1968 issue of a high fidelity magazine, it was published saying, "It
more easily than the characteristic of AR announcement exceeded the test
result", and popularity was acquired.
and the only one made by Acoustic Research
which is a company known for their speaker products. Front panel is in excellent
condition. Slight on the top cover. 240 VAC mains operation
Rating of a mode
Form | Integrated Amplifier |
Output (r. per m.s and channel) | More than 60W (4ohms) 50W (8ohms) 30W (16ohms) |
Frequency response | 20Hz-20kHz±1dB |
Harmonic distortion | 0.5% (20Hz - 20kHz) |
IM distortion | 0.25% (at the time of 60:7kHz=4:1, a Phono input, and an Output power) |
Signal to noise ratio | Phono:57dB Tuner, Tape: 75dB |
Dumping factor | 8-20 (4ohms) 16-40 (8ohms) 32-80 (16ohms) |
Input sensitivity | Phono: 2-5mV sensitivity adjustment is possible. Tuner, Tape: 200mV |
Tone control | Adjustment according to height and right and left is possible at a same axle type. |
Mode | stereo, mono, null |
Power consumption | 125W At the time of the maximum except take-off: 500W |
Dimensions | Width 385x height 115x depth of 255mm |
If interest pls call me chung 012-8877916 thanks
chung- Frequent Contributor
- Number of posts : 156
Registration date : 2010-02-10
» Acoustic Research (AR) Integrated Amplifier A-06
» Acoustic Research (AR) Stereo Integrated Amplifier A-06 with MM and MC
» AS-Acoustic System Desktop Integrated Amplifier
» Audio Research I/50 Integrated Amplifier (Used)
» Unison Research Sinfonia Integrated Amplifier
