MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets
MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets Empty MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets
Post by john_online_shop Mon Dec 18, 2017 2:39 pm
Brand new unit
Estimate Price: RM2,385
Contact: John 0124831410
Note: This item will send from oversea and will take 14 - 21 days to received the item
Please contact me first to check stock availability with my oversea supplier.
MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets Ms-hd-power-ms-e02s-silver-6-ways-uk-filter-sockets-bluezircon-1708-02-bluezircon@24
MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets Mshdghunjmk
  • Please note: This block comes in Silver, 24K Gold and Rhodium finishes. Please select from the dropdown menu.
FEATURES:
  • Multi-stage A/C line filter with PRRT™️ noise suppressor to improve audio and video quality.
  • 6 premium grade sockets with high spring rate phosphor bronze clips to assure tight connection.
  • 3.0 µm pure 925 silver plating to all power clips and IEC inlet for purified signals transmission.
  • 5mm² power transmission bus bars with 1.0 µm pure silver plating enhances high current flow.
  • 4mm² silver plated 6N OFC internal wires with silver-rich soldering.
  • Type-C14 IEC inlet to adapt user-selected power cords.
  • 72,000 Amp. surge suppression protects Hi Fi / AV appliances.
  • Super Heavy gauge metallic chassis with spikes for vibration absorption.
  • Rapid response resettable safety switch protects equipment connected.
  • Fully approved by BSI and complied with BS-1363/A and BS-5733/A standards.
SPECIFICATIONS:
[th]Number of outlets:[/th][th]Type of outlets available:[/th][th]Standard mains inlet:[/th][th]Mains Voltage :[/th][th]Max. Current :[/th][th]Max. Wattage :[/th][th]Max. Surge Suppression:[/th][th]Dimensions :[/th][th]Net Weight:[/th]
6
UK Unswitched
IEC C-14
200 - 240 VAC / 50~60Hz
13 Amp.
3,120 Watt (240V)
2,100Joule / 72,000A
110mm x 410mm x 92mm (W x L x H)
2.6 KG (net)
MS-E02S Gold 6-Ways UK Filter Sockets
FEATURES:
  • 100% Comply with BS-1363 and BS-5733 Safety Standards
  • Multi-Stage A/C Line Filter with PRRT Noise Suppressor Embedded
  • Selected Premium Quality Filtering Components From Germany
  • 6 Premium Grade Sockets High Spring Rate Phosphor Bronze Sockets Clips Pass the BS Standard 30,000 times plug IN / OUT test
  • 3.0 µm 24K Gold Plating to All Power Clips
  • 5 mm² Power Transmission Bus Bars with 1.0 µm Pure Silver Plating Enhances High Current Flow
  • 4mm² Silver Plated 6N OFC Internal Wires with Silver-Rich Soldering
  • 3.0 µm 24K Gold Plated IEC Inlet Adapts User-Selected Power Cords
  • Heavy Gauge Metallic Chassis with Vibration Absorption Spikes
  • 20A Resettable Safety Switch Protect Equipment Connected
  • Full Life-Time Warranty
SPECIFICATIONS:
6
UK Unswitched
IEC C-14
13 Amp.
3,000 Watt (230V)
for MS-E02S 24K Gold only*
2.6 KG (net)
MS-E02S Rhodium 6-Ways UK Filter Sockets
FEATURES:
  • 1.0 µm Rhodium Quadri-Plated Coating to All Power Clips
  • 1.0 µm Rhodium Plated IEC Inlet Adapts User-Selected Power Cords
SPECIFICATIONS:
6
UK Unswitched
IEC C-14
13 Amp.
3,000 Watt (230V)
for MS-E02S Rhodium only*
2.6 KG (net)
john_online_shop
john_online_shop
Number of posts : 35
Registration date : 2017-06-22
Source(s): NAD C568
Amplification: NAD C375BEE
Speakers: Dynaudio DM 2/6
http://bluezircon.lelong.com.my
