Focal Electra 1028Be
Item: FOCAL Electra 1028Be
Condition:9/10. Item in excellent condition, looking and sounding perfect
Price: SOLD, Thank you Hi-FI 4 Sale!
Contact: 012-6767388
THREE-WAY FLOORSTANDING LOUDSPEAKER
Electra 1028 Be is our flagship model of the range. This is particularly thanks to the Powerflow double port system, which greatly enhances the performance of the bass. The dynamics have also been immensely improved to match the generous definition of the higher mid-range register, which will always be an industry reference.
This is a high-end compact floorstanding loudspeaker with undeniable charm.
The most balanced loudspeaker of the line, Electra 1028 Be is a high-end floorstander offering dynamic, generous and precise sound.
Optimised acoustic performance
'W' CONE
The 'W' composite sandwich cone permits total optimization of the frequency response curve, thanks to the total control of three key parameters: lightness, rigidity and damping. These unique characteristics of lightness and rigidity provide control of the signal transmission speed inside the material.
Beryllium tweeter
Due to its incredible rigidity, Beryllium represents the ultimate material for a tweeter dome. After two years of research and development, Focal produced a world first: a pure Beryllium inverted dome, able to cover more than five octaves. You will improve the perception of transients and other micro details. As well, the linearity of the speaker’s response curve is mainly a function of three opposite parameters: lightness, rigidity and damping.
IAL TWEETER (INFINITE ACOUSTIC LOAD)
Electra 1000 Be loudspeakers feature an innovative technology called IAL (Infinite Acoustic Load). This technology enabled us to design a tweeter with a very wide frequency range capable of extending very low down in frequency response, for relaying the midrange much earlier. This technology allows the frequency range to which the human ear is sensitive to be reproduced by the ultra-light tweeter with exceptional definition.
Hand Made in France.
'W' CONE
Beryllium tweeter
Type | 3-way vented oor standing speaker, Power ow |
Drivers | Two 6 1/2" (16.5cm) "W" woofers 6 1/2" (16.5cm) "W" midrange 11/4" (27mm) pure Beryllium IAL inverted dome tweeter |
Frequency response (+/-3dB) | 34Hz - 40kHz |
Low frequency point (-6dB) | 28Hz |
Sensitivity (2.83V/1m) | 91.5dB |
Nominal impedance | 8Ω |
Minimum impedance | 3.5Ω |
Crossover frequency | 350Hz / 2200Hz |
Recommended ampli er power | 40 - 300W |
Dimensions (HxWxD) | 43 11/16x10 3/8x13 3/4" (1 110x264x350mm) |
Net weight | 72.6lb (33kg) |
kent3888- Club Member
- Number of posts : 49
Registration date : 2016-11-01
» Focal jmlab Electra 906
» Focal Electra 1007Be (Used)
» Focal Electra 1007BE speaker (used)
» focal electra jmlab 906
» Used FOCAL Electra 1028 BE Speakers
