Denon AVR-X6400H 11.2CH Atmos Network AV Receiver
Denon AVR-X6400H 11.2CH Atmos Network AV Receiver Brand New, Now Selling at RM9,499.
Free Shipping Within West Malaysia.
DOLBY ATMOS
杜比全景声
DTS:X
AURO-3D
LATEST HDMI SPECS WITH EARC
最新HDMI规格及EARC
ADVANCED VIDEO SECTION
高级视频部分
HDR / DOLBY VISION
AUDYSSEY MULTEQ XT32
CONNECTIVITY
连通性
DENON + HEOS APP
DSP
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
Main Unit
Output Power 140 W per channel @ 8 Ohms, 20 Hz to 20 kHz, 0.05% THD
175 W per channel @ 6 Ohms, 1 kHz, 0.7% THD, 2-channel driven
250 W per channel @ 6 Ohms, 1 kHz, 10% THD, 1-channel driven
Output Impedance 4 to 16 Ohms
Channels 11.2
Tuner AM / FM
Input Sensitivity 2.5 mV
Frequency Response 10 Hz to 100 kHz (+1, -3 dB) (Direct mode)
Signal to Noise Ratio 102 dB (IHF-A weighted, Direct mode)
Surround Modes DTS: DTS HD Master, DTS Neural:X; DTS Virtual:X-ready
Dolby: Dolby TrueHD, Dolby Surround
Object-Based Audio Support Dolby Atmos, DTS:X, Auro-3D
Video
Upscaling Yes, to near-4K
Pass-Through 4K/60 Hz, 4:4:4 color resolution, HDR10, Dolby Vision, HLG, BT.2020, 3D, CEC
Deep Color / x.v. Color Support Yes / Yes
HDMI Version 2.0a
HDCP Version 2.2
Tuner Section
FM Frequency Range 87.5 to 107.9 MHz
AM Frequency Range 530 to 1710 kHz
Sensitivity Effective, FM: 1.5 μV (14.8 dBf) Effective, AM: 20 μV
S/N Ratio IHF-A, FM, Mono: 78 dB
IHF-A, FM, Stereo: 68 dB
IHF-A, FM, HD: 85 dB
IHF-A, AM: 85 dB
Distortion FM, Mono: 0.1%
FM, Stereo: 0.2%
FM, HD or AM: 0.02%
Connectivity
Bluetooth Version: 3.0 + EDR (Enhanced Data Rate)
Transmission Power: Bluetooth Specification Power Class 1
Maximum Communication Range: Approximately 98.4' (30 m) in line of sight
Frequency Range: 2.4 GHz
Modulation Scheme: FHSS (Frequency-hopping Spread Spectrum)
Supported Profiles: A2DP (Advanced Audio Distribution Profile) 1.2, AVRCP (Audio Video Remote Control Profile) 1.5
Corresponding Codec: SBC
Transmission Range (A2DP): 20 Hz to 20 kHz
Wi-Fi Network Type: IEEE 802.11a/b/g/n
Security: WEP 64-bit, WEP 128-bit; WPA/WPA2-PSK (AES); WPA/WPA2-PSK (TKIP)
Frequency Range: 2.4 GHz, 5 GHz
AirPlay Yes
Inputs 8 x HDMI (1 front)
2 x optical TOSLINK
2 x digital coaxial
2 x component video
5 x composite video (1 front)
8 x stereo RCA audio (1 front, 1 phono)
1 x USB (front)
Outputs 3 x HDMI (1 ARC-compatible, 1 Zone 2)
2 x composite video
1 x component video
1 x 2-channel Zone 2 stereo pre-out
1 x 2-channel Zone 3 stereo pre-out
1 x 11.2-channel pre-out
1 x 1/4" (6.35 mm) headphone (front)
Other Ports 1 x setup microphone input (front)
1 x Denon Link HD
1 x FM antenna
1 x AM antenna
2 x Bluetooth / Wi-Fi antenna
1 x Ethernet
1 x AC power cord
1 x IR remote in
1 x IR remote out
1 x RS-232C
2 x trigger out (12 VDC, 150 mA max)
Speaker Connectors 11 x binding post pairs
HDMI CEC Yes
Audio Return Channel (ARC) Yes, on main HDMI output
HDCP Compliance HDCP 2.2 on all ports
General
On-Screen Display Yes
Power Requirements 120 VAC, 60 Hz
Power Consumption Operational: 750 W
Operational, No Sound, ECO On: 65 W
Operational, No Sound, ECO Off: 110 W
Standby: 0.1 W
CEC Standby: 0.5 W
Dimensions (W x H x D) 17.1 x 6.6 x 15.1" (43.4 x 16.7. x 38.3 cm)
Weight 37.7 lb (17.1 kg)
Packaging Info
Package Weight 38.6 lb
Box Dimensions (LxWxH) 20.5 x 18.0 x 11.0"
AMAZING 3D-SOUND.
Enjoy the most complete surround sound experience with latest audio formats Dolby Atmos, DTS:X and Auro-3D built-in. Most remarkably, the 11 channel amplification allows for setting up a full 7.1.4 3D experience without the need of an external amplifier.惊人的3D声音。
通过最新音频格式杜比全景声、DTS:X和内置Auro-3D享受最完整的环绕声体验。最值得一提的是,11声道放大允许设置全7.1.4 3D体验而无需外部放大器。POWERFUL 11.2 CHANNEL AMP WITH ECO MODE.
The AVR-X6400H features a sophisticated power amplifier section with 11 channels in a monolithic amplifier design for ultimate clarity and power. Each channel is rated at 205 watts and all channels are able to safely drive lower impedance speakers (down to 4 ohms). There’s also an Auto Eco mode that adjusts the maximum power available according to the volume level as well as an on-screen Eco meter that lets you see the power consumption reduction in real time.带ECO模式的强大11.2声道放大器
AVR-X6400H配备了精密功率放大器部分,有11个声道,每声道采用单片式放大器设计,以提供终极清晰度和功率。每个声道额定功率为205瓦,所有声道都能安全驱动低阻抗扬声器(低至4 Ω)。还有会根据音量自动调节最大可用功率的Auto Eco模式,以及能让您实时看到功耗减少情况的屏上节能显示功能。READY FOR THE FUTURE OF HOME CINEMA.
The AVR-X6400H’s advanced video section is fully compatible with the latest HDMI and HDCP 2.2 specifications and prepared for any 4K Ultra HD source. High Dynamic Range (HDR), Dolby Vision compatibility, Hybrid Log Gamma (HLG) and eARC (enhanced Audio Return Channel) are at hand as well. You can also enjoy ultra-high-definition pictures from legacy analogue and digital sources.预升级未来的家庭影院。
AVR-X6400H的高级视频部分完全兼容最新的HDMI和HDCP 2.2规格,为所有4K超高清源做好准备。高动态范围(HDR)、Dolby Vision兼容性、Hybrid Log Gamma (HLG)和eARC(增强型音频回传通道)也即将提供。您还可以从传统的模拟和数字源欣赏超高清画面。THE HEART OF YOUR WIRELESS NETWORK.
Every sound, all your music, controlled effortlessly. Full wireless connectivity is provided via both Wi-Fi and Bluetooth, Apple Airplay is supported. The built-in HEOS technology allows the AVR-X6400H to become the app-controlled heart of a whole-house wireless multi-room sound network.您无线网络的核心。
轻松控制各种音响、所有的音乐。通过Wi-Fi和蓝牙提供完整的无线连接性,支持Apple Airplay。内置HEOS技术使AVR-X6400H成为全住宅无线多房间音响网络的App控制核心。PERFECT SET-UP FROM THE START.
The AVR-X6400H easily guides you through the set-up process to ensure the most accurate configuration. Optimize all settings for the best possible sound and video quality with your system from the get-go. The most advanced Audyssey MultEQ XT32 room measurement system provides for best sound in every room.从头开始完美设置。
AVR-X6400H轻松指导您完成整个设置过程,确保拥有最精确的配置。从一开始就优化所有设置,使您的系统拥有尽可能最好的声音和视频品质。最先进的Audyssey MultEQ XT32室内测量系统为每个房间提供最佳声音。BLOCKBUSTING 3D-SOUND.
Surround yourself in cinema-grade sound from literally any direction.惊人的3D音效。
能从任何方向将您环绕在影院级音效中。DOLBY ATMOS
SOUND IN THE RIGHT PLACE.
Feel every dimension in Dolby Atmos. Dolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Enjoy a 5.1 or 7.1 surround sound speaker system and 4 additional overhead speakers or 4 Dolby Atmos elevation speakers for the ultimate home theatre experience - including Dolby Surround upmixer for legacy content.杜比全景声
正确到位的声音。
全方位感受杜比环绕声。杜比全景声通过具有惊人真实性的环绕移动音频,让您随剧情身临其境。只需一个5.1或7.1环绕声扬声器系统和4个附加顶置扬声器或4个杜比全景声高位扬声器,即可享受终极家庭影院体验——包括用于传统内容的杜比环绕声上混频器。DTS:X
BE CLOSER TO THE ACTION.
DTS:X™ immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The improved immersion and heightened realism draw you into the world of your favourite movies. The included spatial remapping engine, DTS Neural:X™, gives your movie, game and music collections a new lease on life! DTS:X brings the theatre home.与情景更接近。
DTS:X™沉浸式音频将声音置于它在空中的自然发出位置,在家中创建逼真的多维音频体验。改善的沉浸感和提高的真实性将您带入最喜欢电影的世界。附带的空间重映射引擎,DTS Neural:X™,给您的电影、游戏和音乐收藏带来新生!DTS:X将影院搬进家庭。AURO-3D
PUTTING YOU IN A COCOON OF LIFE-LIKE SOUND.
Auro-3D® elevates the home theatre experience to amazing new levels by delivering the excitement of three-dimensional sound for music, games, broadcast, and films while enhancing your existing audio-visual collection, thanks to Auromatic up-mixing engine.把您笼罩在逼真声音氛围内。
Auro-3D®将家庭影院体验提升至惊人的新高度,为音乐、游戏、广播和电影带来三维声音的刺激,同时增强了您现有的视听收藏,这归功于Auromatic Up-Mixing引擎GEARED UP FOR 4K ULTRA HD.
Enjoy ultra-high-definition pictures, even from analogue and digital SD sources.[size=30]支持4K超高清。[/size]
即使从模拟以及数字SD源也能欣赏超高清图像。LATEST HDMI SPECS WITH EARC
FUTUREPROOF IN ANY WAY.
All eight HDMI inputs and two HDMI outputs feature HDCP 2.2 compatibility and the latest HDMI specifications, including 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, High Dynamic Range (HDR) and 21:9 video, 3D, and BT.2020 pass-through support. It is even ready for Enhanced Audio Return Channel (eARC) for 3D audio broadcast over TV.最新HDMI规格及EARC
完全面向未来。
全部八个HDMI输入和两个HDMI输出都具备HDCP 2.2兼容性和最新的HDMI规格,包括支持4K超高清60Hz视频、4:4:4纯色子采样、高动态范围(HDR)和21:9视频、3D和BT.2020直通。甚至已为增强型音频回传通道(eARC)做好准备,可通过电视App在电视机上进行3D音频广播。此功能将通过未来固件更新启用。ADVANCED VIDEO SECTION
BREATH NEW LIFE INTO LEGACY SOURCES.
The AVR-X6400H owns an advanced video processor to upscale existing lower resolution video from any analogue or digital source to true 4K. With three HDMI outputs, you can even connect a TV and a projector in the main room, while playing back different content on a second zone screen.高级视频部分
使传统源获得新生。
AVR-X6400H拥有高级视频处理器,可将现有来自模拟或数字源的低分辨率视频升频至真正的4K视频。带有三个HDMI输出,您甚至可以在主房间连接电视机和投影仪,同时在第二区域屏幕上播放不同的内容。HDR / DOLBY VISION
NEXT GENERATION VIDEO FORMATS.
The AVR-X6400H supports High Dynamic Range (HDR) video format. It is even ready for Dolby Vision and HLG (Hybrid Log Gamma). Dolby Vision transforms the viewing experiences with astonishing brightness, contrast, and colour. HLG offers HDR technology over broadcast content.下一代视频格式。
AVR-X6400H支持高动态范围(HDR)视频格式。甚至已为Dolby Vision和HLG (Hybrid Log Gamma)预升级。Dolby Vision以令人惊叹的亮度、对比度和色彩转变人们的观看体验。HLG在广播内容上提供HDR技术。SET-UP AND CONNECT WITH EASE.
Get your AVR-X6400H up and running in no time, perfectly tailored to your needs.设置和连接极其方便。
安装好AVR-X6400H后很快就能运行,完全按您的需求定制。AUDYSSEY MULTEQ XT32
MEASURE YOUR SOUND TO YOUR ROOM.
The AVR-X6400H features the most advanced Audyssey MultEQ XT32 room acoustic measurement system including Audyssey Dynamic Volume, Dynamic EQ, LFC and SubEQ HT. Through these technologies, and with the supplied microphone, it exactly analyses each speaker's output to optimize the overall listening experience. With the additional Audyssey MultEQ Editor App (available for purchase), very advanced users can even go further "under the hood" if desired.测量您房间的声音。
AVR-X6400H具备最先进的Audyssey MultEQ XT32室内声音测量系统,包括Audyssey Dynamic Volume(动态音量)、Dynamic EQ(动态均衡器)、LFC和SubEQ HT。通过这些技术,并使用附带的麦克风,它能精确分析各扬声器的输出以优化总体聆听体验。另外使用 Audyssey MultEQ Editor App (可购买),专家用户甚至可以根据需要进一步进行“调校”。CONNECTIVITY
UNWIRE YOUR SOUND.
The AVR-X6400H is equipped with an advanced dual antenna system for robust and error-free streaming, featuring Bluetooth and Wi-Fi connectivity as well as Apple's AirPlay for direct music playback from Apple's iDevices.连通性
无线连接您的音响。
AVR-X6400H配备高级的双天线系统,实现可靠且无错误的串流传输,具有蓝牙和Wi-Fi连接功能以及Apple的AirPlay,可从Apple的iDevice直接播放音乐。DENON + HEOS APP
EVERYTHING UNDER CONTROL.
With the "Denon 2016 AVR Remote" app you can control the receiver's operation and even control your connected Denon Blu-ray player. With the HEOS app you easily command your music and multi-room streaming.一切尽在掌控。
利用“Denon 2016 AVR Remote”App,您可以控制接收机的操作,使用HEOS app,您可以轻松掌控您的音乐和多房间串流。选择您最喜欢的源。
为您储存每个源的首选设置和声音模式,让您可以通过按前面板和遥控器上的按钮直接跳转这些源。ADVANCED SOUND PROCESSING.
Experience extraordinary sound quality from both music and movies.高级声音处理。
体验来自音乐和电影的非凡音质。DSP
POWERFUL DSP AUDIO PROCESSING.
The AVR owns a sophisticated DSP audio processing system that incorporates no less than 4 powerful high speed fourth generation SHARC DSP processors, which together have a combined continuous processing capability of 10 GFLOPS (10 billion floating point numerical computations per second).强大的DSP音频处理。
AVR拥有精密的DSP音频处理系统,该系统采用了至少4个强大的高速第四代SHARC DSP处理器,拥有10 GFLOPS(每秒100亿次浮点数值计算)的综合连续处理能力。Please visit [You must be registered and logged in to see this link.] to find out more products for sale at very special price..
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
Main Unit
Channels 11.2
Tuner AM / FM
Video
HDMI Version 2.0a
HDCP Version 2.2
Tuner Section
IHF-A, AM: 85 dB
FM, Stereo: 0.2%
FM, HD or AM: 0.02%
Connectivity
AirPlay Yes
2 x optical TOSLINK
2 x digital coaxial
2 x component video
1 x USB (front)
2 x composite video
1 x component video
1 x Denon Link HD
1 x FM antenna
1 x AM antenna
1 x Ethernet
1 x AC power cord
1 x IR remote in
1 x IR remote out
1 x RS-232C
HDMI CEC Yes
General
Standby: 0.1 W
CEC Standby: 0.5 W
Packaging Info
- Number of posts : 1323
» Denon AVC-X6500H 11.2 Ch Atmos Network Av Receiver
» Denon AVR-S750H 7.2CH Atmos Network AV Receiver
» Denon AVR-X1800H 7.2Ch Atmos Network AV Receiver
» Denon AVR-S760H 7.2Ch 8K Atmos Network AV Receiver
» DENON AVR3300 7.2 ATMOS Network AV Receiver NEW
