Marantz NA6005 Network Audio Player (Sold Out)
Marantz NA6005 Network Audio Player Brand New, Now Selling at RM3299. Free Shipping Within West Malaysia.
Enjoy a thrilling high-resolution audio experience with the Marantz NA6005 network audio player, which features built-in Wi-Fi® and Bluetooth wireless streaming via dual Wi-Fi/Bluetooth antennas, and built-in Spotify Connect®music streaming via your home network as well as AirPlay® and internet radio.
Featuring advanced audiophile design and construction, the NA6005 delivers superlative high-resolution audio via the reference-class CS4398 high current D/A converter that's coupled with a dedicated jitter removal system, along with 2.8 and 5.6 MHz DSD file compatibility (the file format for high resolution SACD).
Via the available Marantz Hi-Fi Remote App (iOS; Android™) you can easily operate the NA6005 from your favorite portable device, and the NA6005 also features a convenient front panel USB port for connection to portable devices and USB drives.
使用马兰士NA6005网络音频播放机可享受令人兴奋的高解析度音频体验,本机具备内置Wi-Fi和蓝牙无线串流功能,配备了双Wi-Fi/蓝牙天线,还有内置Qplay音乐串流功能,可通过家庭网络以及AirPlay和互联网收音机欣赏音乐。
NA6005具有高级高保真设计和结构,通过与专用时基误差消除系统耦合的参考级CS4398高电流数模转换器带来出色的高解析度音频,同时兼容2.8和5.6 MHz DSD文件(高解析度SACD的文件格式)。
可通过Marantz Hi-Fi App (支持iOS、Android)轻松地从您最喜欢的便携式设备操作NA6005,且NA6005前面板还配备了USB 2.0端口,方便用于连接便携式设备和U盘。
Exclusive HDAM Technology
HDAM专利技术
Equipped with our renowned HDAM technology, the NA6005 features multiple HDAM and HDAM-SA2 modules in critical circuit blocks, including the analog output stage and the headphone amplifier circuit. Compared to conventional IC op-amps, HDAM discrete circuit elements technology delivers ultra high slew rate and high bandwidth to ensure purist audio sound quality.
NA6005配备了马兰士著名的HDAM技术,在关键的电路模块中配备了多个HDAM和HDAM-SA2模块,包括模拟输出级和耳机放大器电路。与传统的IC运算放大器相比,HDAM分离式电路元件技术具有超高转换速率和高带宽以确保最纯正的音频音质。
Premium Grade CS4398 D/A Conversion
高级CS4398数模转换器
Featuring the reference-class high current CS4398 D/A converter handling PCM 24-bit/192-kHz and bitstream DSD, the NA6005 delivers superb fidelity and dynamic range with high resolution audio file formats including PCM and DSD.
NA6005配置参照级高电流CS4398数模转换器,能处理PCM 24位/192-kHz和比特流DSD文件,给高解析度音频文件格式(包括PCM和DSD)带来超凡的保真度和动态范围。
Advanced Jitter Reduction System
高级时基误差抑制系统
Working in concert with the CS4398 D/A converter, the NA6005's jitter reduction circuit features a dedicated timing data re-clocking system that eliminates distortion caused by poor timing stability in the incoming audio data stream.
配合CS4398数模转换器,NA6005的时基误差抑制电路具备专用的时序数据重定时系统,能消除输入音频数据流因时序稳定性不良造成的失真。
Built-in Wi-Fi & Bluetooth with Dual Diversity Antennas and Dual Band "N"
内置Wi-Fi和蓝牙功能以及双分集天线和双频带“N”
For optimum Wi-Fi and Bluetooth transmission and reception, the NA6005 boasts highly sophisticated next-generation technology that features dual diversity antennas with individual internal wave guides along with a powerful RF section equipped with dual core 300 MHz DSP processors that help to ensure solid, stable streaming and decoding, even in crowded urban environments.
The Wi-Fi section features dual band "N" high speed auto-band switching technology that constantly seeks out the optimum channels to ensure smooth and glitch-free listening. Via the WPS and iOS Wi-Fi protected setup buttons, you can connect your device with the NA6005 in moments. Via Bluetooth, the NA6005 will remember pairing information of up to 8 devices.
为实现最佳的Wi-Fi和蓝牙发送和接收,NA6005采用高度成熟的下一代技术,配备带独立内部波导的双分集天线,其强大的RF部分配备双核300 MHz DSP处理器,以确保即使在拥挤的城市环境下也有牢靠、稳定的串流和解码能力。
Wi-Fi部分具备双频带“N”高速自动频带切换技术,能持续搜寻最佳频道以确保顺利无干扰的收听效果。通过WPS和iOS Wi-Fi保护设置按钮,可以立即将您的设备与NA6005配对,NA6005能记住最多8个设备。
Built-in Spotify Connect Music Streaming; Apple AirPlay; Internet Radio
内置Qplay音乐串流、Apple AirPlay、互联网收音机
Available as a free (with ads) or paid subscription (no ads) streaming music service, Spotify boasts one of the largest catalogs of streaming audio recordings in the world, and the NA6005 features Spotify Connect app compatibility.
Owners of popular iOS devices, including the iPod touch®, iPhone® and iPad® can instantly stream their favorite tracks from their iTunes® library via AirPlay, which provides one touch automatic turn-on and source selection. The NA6005 is also DLNA® 1.5 certified for streaming content from your home PC, laptop PC or Mac®.
You can also choose from literally thousands of internet radio stations from around the globe, with a tremendous range of music genre choices.
作为免费或付费订阅串流音乐服务,QQmusic拥有大量串流音频资源和广泛的用户基础,而NA6005兼容其Qplay功能。
流行iOS设备(包括iPod touch、iPhone和iPad)的拥有者可以通过AirPlay(提供一触自动打开和曲目选择)从其iTunes资料库立即串流最喜欢的曲目。NA6005还获得DLNA 1.5认证,可从您的家庭PC、笔记本电脑或Mac串流音频内容。
还可以从全球数千互联网电台选择不同音乐流派的作品。
Wide Range of File Types Supported, Including 2.8 & 5.6 MHz DSD
广泛支持各种文件类型,包括2.8和5.6 MHz DSD
In addition to compatibility with conventional PCM audio tracks from digital audio sources such as CD, the NA6005 supports no less than 8 additional audio file types:
除了兼容来自CD等数字音频源的传统PCM音频曲目外,NA6005还支持至少另外8种音频文件类型:
The NA6005 supports gapless audio playback with WAV, FLAC, ALAC, AIFF and DSD file types.
NA6005支持WAV、FLAC、ALAC、AIFF和DSD文件类型的无缝音频播放。
Standalone D/A Converter Capability
独立D/A转换器功能
Via the optical digital input you can use the NA6005 as an audiophile D/A converter when connected to a digital disc player or other digital audio source with an optical digital output.
当连接至数字光盘播放机或带光纤数字输出的其他数字音频源时,可通过光纤数字输入将NA6005用作高保真D/A转换器。
Audiophile Construction
发烧级设计构造
The substantial chassis features dual layer chassis foundation construction. Instead of having just 1 large circuit board, the NA6005 features multiple individual circuit cards to prevent mutual interference - even the headphone output features its own dedicated circuit board.
Inside, the NA6005 is packed with premium grade active and passive components, including multiple high speed, high current Shottky barrier diodes that boast super fast recovery times and high reverse current protection, plus audiophile grade capacitors and precision tight tolerance resistors.
底盘坚固,具有双层底盘基础结构。NA6005以多块独立电路板取代单块大电路板,以防相互干扰 - 甚至耳机输出也专门设计的电路板。
NA6005内部装有高品质主动和被动元件,包括多个高速、高电流肖特基二极管,拥有超快响应时间和高逆流保护功能,外加高保真级电容器和高精密电阻器。
Standby Recharging System
待机充电系统
Featuring smart device recharging, when a device such as a smartphone or tablet is connected to the NA6005's USB port and the NA6005 is put into standby, it continues to charge the device. Once the device is fully charged, the NA6005 enters very low power standby mode for minimal power consumption (less than 1/2 watt).
NA6005具备智能设备充电功能,当智能手机或平板电脑等设备连接至NA6005的USB 2.0端口且NA6005处于待机状态时,会持续对设备进行充电。一旦设备充满电,NA6005会进入极低功率待机模式,实现最低功耗(低于½瓦)。
Multiple Control Options
多个控制选项
Supplied with an ergonomic remote control that's also compatible with Marantz Integrated Amplifiers, the NA6005 also supports the new Marantz Hi-Fi Remote app (iOS/Android) via your home network. The rear panel includes remote control input and output ports for direct connection to a Marantz disc player and an infrared (IR) flasher input for connection to an external control device, along with an RJ-45 LAN port.
NA6005附带符合人体工学的遥控器,且同时兼容马兰士光盘播放机,还能通过家庭网络支持最新Marantz Hi-Fi Remote app (iOS/Android)。后面板附带遥控输入和输出端口,可直接连接马兰士光盘播放机,以及红外(IR)输入,可连接外部控制设备,还配备RJ-45 LAN端口。
超过60年的高保真传承
Founded in 1953, Marantz has a long and rich history of designing audio components that have been embraced by music lovers and critical listeners around the world. Because Music Matters so much in our lives, the NA6005 carries on our long tradition of delivering a superlative music listening experience, and it's equipped to deliver the ultimate home theater experience as well.
马兰士创办于1953年,具有悠久丰富的高保真元件设计历史,其元件备受全球音乐爱好者和挑剔发烧友的推崇。因为音乐在我们生活中不可或缺,NA6005延续了提供出色音乐收听体验的悠久传统。
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
front-panel USB input for connecting an iPod, iPhone, or thumb drive
direct digital connection for iPod or iPhone bypasses the device's digital-to-analog converter for better sound
output stage uses Marantz's latest generation Hyper Dynamic Amplifier Modules (HDAM) for low noise and lifelike sound
free Marantz Remote app available for Apple and Android devices
gapless playback with FLAC, ALAC, WAV, AIFF, and DSD files
AM/FM radio tuner
remote control
Connections and Dimensions:
HDAM专利技术
Analog audio circuit | Headphone amplifier |
高级CS4398数模转换器
高级时基误差抑制系统
WMA | 32/44.1/48 kHz | 48-192 kbps | - | .wma |
MP3 | 32/44.1/48 kHz | 32-320 kbps | - | .mp3 |
WAV | 32/44.48/88.2/96/176.4/192 kHz | - | 16/24 bits | .wav |
MPEG-4 AAC | 32/44.1/48 kHz | 16-320 kbps | - | .aac/.m4a/.mp4 |
FLAC | 32/44.48/88.2/96/176.4/192 kHz | - | 16/24 bits | .flac |
ALAC | 32/44.1/48/88.2/96 kHz | - | 16/24 bits | .m4a |
AIFF | 32/44.48/88.2/96/176.4/192 kHz | - | 16/24 bits | .aif/.aiff |
DSD (stereo) | 2.8 MHz-5.6 MHz | - | - | .dsf/.dff |
独立D/A转换器功能
发烧级设计构造
待机充电系统
多个控制选项
60+ Years of Audiophile Heritage |
超过60年的高保真传承
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
Product Highlights:
- plays digital music from computers, music servers, and online services with your home stereo system
- Cirrus Logic CS4398 DAC (digital-to-analog converter) for high-performance playback of digital music
- built-in Wi-Fi for easy connection to a wireless home network
- Bluetooth wireless connectivity for streaming music from compatible smartphones, tablets, and computers
- dual-diversity antennas and dual-band "N" technology ensure solid, stable Bluetooth and Wi-Fi streaming
- Apple AirPlay for streaming music from an iPhone, iPod touch, iPad or iTunes on your computer
- DLNA 1.5 certified for streaming music wirelessly from compatible computers and network-attached storage (NAS) drives
- includes support for Pandora, vTuner Internet radio, and SiriusXM (subscription required for SiriusXM)
- Spotify Connect lets you play Spotify's streaming music library via Wi-Fi, controlled by your smartphone or tablet (requires Spotify app and a premium subscription)
- high-resolution playback of DSD, FLAC, WAV, AIFF, and ALAC files; also plays MP3, WMA, and AAC files
- up to 24-bit/192kHz resolution for PCM files; up to 5.6MHz resolution for DSD files
- stereo analog RCA outputs
- optical digital audio input
- optical digital audio output
- Ethernet port
- front-panel USB input (Type A) for connecting an iPod or compatible USB memory device
- discrete headphone amplifier with 1/4" output and volume control
- IR flasher input for use with external controllers
- detachable power cord
- 17-3/8"W x 4-3/16"H x 15-1/4"D
- weight: 13.23 lbs.
- Number of posts : 1323
» Marantz ND8006 Network Music /CD Player Japan Made (Sold Out)
» Marantz Network Audio Player
» Marantz ZC4001 network audio player (used)
» Marantz Reference NA-11S1 Network Audio Player/DAC
» Marantz NA11s1 Reference DAC & Network Audio Player
