Monitor Audio Mass 5.1 Home Theater System
Monitor Audio Mass 5.1 Home Theater System Brand New. Now Selling At RM5,369. Free Shipping Within West Malaysia.
AWARDS
Mass W200
The W200 is a subwoofer with a potent 220 W DSP controlled Class D amplifier. It powers a side-firing 10" long throw C-CAM bass driver equipped with a huge, dual stack magnet system. Complementing the active driver is a 10" Auxiliary Bass Radiator (ABR). Select ‘music’, ‘movie’ and ‘impact’ pre-set response curves using a back-panel switch.
Technology
Specification:
Mass 10
224 x 128 x 128 mm
813/16 x 51/16 x 51/16"
Mass Centre
128 x 228 x 128 mm
51/16 x 813/16 x 51/16"
Mass W200
420 x 385 x 385 mm
169/16 x 163/16 x 163/16"
System Format
Active sub-woofer system - Auxilary (ABR) loading. 18 mm MDF cabinet (CARB2 approved)
Lower Frequency Limit
30 Hz (-6 dB)
Upper Frequency Limit
Variable 40 - 120 Hz @ 24 dB/Octave
Amplifier Output
220 watts @ 1% THD+N
Amplifier Classification
Class - D amplifier with Switch mode power supply (SMPSU)
Bass EQ Profiles
Music / Movie / Impact
Phase Control
0-180 degrees
Auto Sensing
Line Level >3.5mmV
Input Level Requirements
Standby after approx. 20 minutes if no signal sensed
Drive Unit Complement
1 x 10" (250 mm) C-CAM Long Throw Driver
1 x 10" (260 mm) Auxilary bass radiator
Input Impedance
> 20 ohms
Mains Input Voltage
100 - 120 Vac / 220 - 240 Vac 50/60Hz (Factory Region Present)
Dimensions (Including Grilles & Feet (H x W x D))
420 x 385 x 385 mm / 169/16 x 163/16 x 163/16"
Connection
Stereo RCA in, LFE in, 12v Trigger in (3.5 mono mini-jack)
Trigger Input
5 12v via 3.5 via mono mini-jack socket
Power Consumption
200 watts / 0.5 watts in Standby (ErP approved)
Weight
15.96 kg (35 lb, 2 oz)
BRANDED led tv
amplifier
speaker
cd player
Mass 5.1
Monitor Audio’s compact MASS home cinema system. Its sculpted space-efficient design, packed with technology and easy-installation features, offers jaw-dropping audio dynamics with décor-friendly styling, making the introduction of home cinema sound into any living space a simpler and more satisfying experience.AWARDS
Technology
- 4" bass midrange driver featuring C-CAM cone technology.
- Specially developed 1" C-CAM tweeter design featuring unique venting and rear loading chamber – low resonance design to provide clean, pure sound.
- Damped polymer moulded cabinet with internal ribbing.
- The curved shape helps to eliminate un-wanted standing waves.
- Single point fixing (1/4" UNC) for universal wall bracket installation (not provided).
- Concealed, discreet cable termination inside end cap using binding post type connection.
- Single bolt through driver and bracing system, for increased overall bracing and rigidity.
- Single rear mounted port featuring HiVe technology for clean, powerful, punchy bass.
- Black cloth finish with contrasting solid aluminium end caps.
- Optional floor-stand with internal (pre-wired) cable management system.
- 10" flat ABR (Auxiliary Bass Radiator)
- 220watt class-D power amplifier
- DSP providing accurate filter characteristics
- Advanced limiters designed to ensure the W200 never loses control.
- 3 x pre-set bass modes (Music, Movie, Impact)
- 12 V trigger input – ensures W200 switches on and off with other equipment.
- Heavy duty MDF construction
Mass W200
Technology
- C-CAM cone technology
- Tuned for tight, fast bass punch
- 220 watt class-D power amplifier
- 12V trigger input – ensures W200 switches on and off with other equipment.
- Discreet black cloth finish.
Specification:
Mass 10
224 x 128 x 128 mm
Mass Centre
128 x 228 x 128 mm
Mass W200
420 x 385 x 385 mm
System Format
30 Hz (-6 dB)
Amplifier Output
Bass EQ Profiles
Phase Control
0-180 degrees
Auto Sensing
Line Level >3.5mmV
Input Impedance
> 20 ohms
Mains Input Voltage
Connection
Trigger Input
Power Consumption
Weight
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1342
» Monitor Audio Mass 2G 5.1 Home Theater System
» Monitor Audio Bronze 5 5.1 Home Theater System
» Marantz NR1711+ Monitor Audio Mass 2G 5.1 Home Theatre Package
» Denon AVR-S960H + Monitor Audio Mass 2G 5.1 Home Theatre Package
» Denon AVR-S660H + Monitor Audio Mass 2G 5.1 Home Theatre Package
