APRIL MUSIC Stello HP100 Pre-Amplifier and S100 Power Amplifier
Post by HiFiLab on Fri Jun 22, 2018 8:25 pm
Stello Pre-Amplifier HP-100
South Korean manufacturer April Music
The Stello 100 series brings beautiful music to budget spaces at budget prices.
FEATURES
# Analog Stage: Full Discrete, Class A Push-Pull
# Power Supply: 2 Stage Voltage Regulator
# Carefully Chosen High Quality Components
# WIMA Polyprophylene Capacitors
# JFET Input Stage (Input Impedance - 1 Mega Ohms)
# ALPS Blue Velvet Volume
# Neutrik XLR Phone Jack
# Specially Designed Toroidal Transformer
SPECIFICATIONS
Analog Input 2 pairs RCA/Unbalanced
Analog Output 1 pair RCA/Unbalanced
Headphone Output 1 Neutrik XLR Phone Jack
Gain Selection High/Low Selectable
Filter Selection A(Off)/B(On) Selectable Frequency Characteristics
Filter Off : 20~200 kHz, On : 20~20 kHz
Output Power 300 mW / 300 Ohms
Power Requirement 100~117VAC, 220~240VAC (Switch Selectable)
Weight(NET) 3.5 kg, 8 lbs.
Stello S100 Power Amplifier
APRIL MUSIC S100 STEREO AMPLIFIER in excellent condition. From the manufacturer: Stello S100 is a power amplifier with 50W of output in STEREO mode.
Stello S100 has a pair of power transistors. To ensure top musical performance and longer life of operation, special circuits are applied which is unique for S100. Stello S100 is a matching power for HP100 preamp/headphone amp. Sized same as the other 100 series product line (HP100 & DA100),
this Stello S100 is a very interesting power which emits 50W per channel. Even though the size of S100 is very compact, the driving power is far beyond your imagination due to the special design concepts from April Music design team. The musicality is just like or more than that of the bigger and more expensive power amplifiers in the market.
Power output: 50 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 45kHz
Total harmonic distortion: 0.02%
Signal to noise ratio: 100dB
Dimensions: 219 x 54 x 296mm
Weight: 3.95kg
Come with Original Box packaging
Price : RM 3600
HiFiLab
Number of posts : 2476
BUMP
Post by HiFiLab on Wed Jul 18, 2018 9:20 am
HiFiLab
