Accuphase - accurate phase
ACCUPHASE - Japan
Accuphase Integrated
E-800 50W Class A rm58k
E-700 35W Class A rm47k
E-5000 Class AB rm54k
E-4000 180w Class AB rm35k
E-380 120w Class AB rm29k
E-280 90w Class AB rm22k
Accuphase Power Amp
A-300 Monoblock 50th Anniversary Model
A-80 65W Class A power amp
A-48 45W Class A power amp
P-7500 Class AB 300w@8ohm 600w@4ohm 900w@2ohm
P-4600 Class AB stable 150W@8ohm 300W@4ohm 450W@2ohm
Accuphase Preamp
C-2300
C-2900
C-3900 50th Anniversary Flagship
Accuphase CD player
DP-450 CDP/DAC
DP-570 CD/SACD
DP-770 CD/SACD
DP-1000 DC-1000 50th Anniversary
Accuphase Phono
C-47 7 MM/MC phono
Audition/Demo available
Br.
Victor 012 296 2799
Hifi Creations
N-9-07 Gamuda Biz Suite
Persiaran Anggerik, Kota Kemuning
40460 Shah Alam
* preferably appointment
[You must be registered and logged in to see this link.] Victor
Website: [You must be registered and logged in to see this link.]
Facebook: [You must be registered and logged in to see this link.]
Distributor and exclusive dealer of Accuphase, Clarisys Audio, Skogrand, Pink Faun Streamer, Acoustic Revive, Revival Audio, Harbeth
Accuphase Power Amp
Accuphase Preamp
C-2300
C-2900
Accuphase CD player
DP-450 CDP/DAC
DP-570 CD/SACD
DP-770 CD/SACD
Accuphase Phono
C-47 7 MM/MC phono
Br.
Victor 012 296 2799
Hifi Creations
40460 Shah Alam
Re: Accuphase - accurate phase
E-470 Integrated Amp and DC-37 DAC review
Accuphase owner will experience extreme 'Linearity' at ANY volume. usually when music is played at low volume, most often u will realise the bass doesnt comes out, small nuances cant be heard, music doesnt comes alive or flow out effortlessly n etc as conventional volume control needs to hit a min volume only then the music comes 'alive'..with Accuphase AAVA Tech, this doesnt happens at all. owner can appreciate music at any volume. Another great advantage of AAVA, extremely low noise and 'quiet background' hence the music imaging 'pops' out distinctly. no more hissing and distortion too.
AAVA tech is applied in all ACCUPHASE Integrated and Preamp lineup
Secret Sauce to Accuphase sound
revolutionary AAVA 'type' volume control
complex design AAVA do not use variable resistors potentiometer. Because music signal do not have to pass through any variable resistors, there is no change in the music signal impedance and no alteration of frequency response. this leads to outstanding S/N ratio and excellent THD of the amplifier is not compromised in any way. same superb sound quality will be obtained at ANY volume. more reliable than ever as no mechanical wear
1. Volume control resolution and precision
2. High S/N ratio and maintains 'uniform' frequency response
3. No more Left/Right tracking differences or crosstalk
4. No click sounds. almost all relay volume controls clicks when relay flips
Accuphase E-370
superb review, scoring all-time high of 96% from German Hifi Magazine
Full coverage PDF Download below:
ACCUPHASE P7300
Accuphase P-7300 800w@1ohm
Price: rm79k
* flagship stereo Class AB amp
* extreme high damping factor of guaranteed 1000, but in reality is more than 2000 ????????????
(superb "control" & "grip" over the woofer)
* extreme low noise, 50% quieter than its predecessor
Accuphase full stack + Steinheim singing 'Amazing Grace' ... enjoy
Accuphase E-650 Class A Flagship Integrated.
Technical Highlights:
* Balanced AAVA preamp stage similar topology to the state-of-the-art(SOTA) C3850 flagship preamp
* Superb high damping factor of guaranteed 800 but in actual 1200 - "iron-fist" bass ????
* Ultra-Low Noise of 102db S/N ratio at max gain
* Power double down X 3 times, stable @ 1ohm
Note: so much goodies rarely seen in any Integrated Amp
This is the new Accuphase E-480. Yeah: MOS-FETs in triple parallel push-pull configuration; 180 watts into 8 ohms; Damping factor 600; fully balanced signal transmission; massive high-efficiency transformer and large filtering capacitors. rm34k each. I want one. Accept no substitute.
1st batch - sold
2nd batch - arriving soon (all pre-sold )
3rd batch - after CNY (available)
1st batch - sold
Accuphase E-480 owners testimonial:
"The Accuphase E-480 has given my system a new leash of life! It was known to my ears for quite sometime that my HECO EINKLANG is underperforming with many missing links in the mids and highs. The introduction of E-480 to the pair of full range speaker gave an entirely new dimension in the sonic performance of the speaker. The mids are more forwarding coupled with clear and more extended highs. The high damping factor of the E-480 gave the lower frequency more authority and control with a sense of solidness that i couldn’t hear previously. A total make-over that realizes the full potential of a mid-fi commodity! A must pre-requisite for every “high-end” electronics! Bravo!
The sensitivity of E-480 towards power cables gave “opportunity” for enthusiast to experiment. The recently tested Skogrand Wagner gave the E-480 a more immersive sound effect." KC
Accuphase E-650 Class A Flagship Integrated + All new Magico A3
"I was skeptical that the E650’s 30w would drive the Magico A3 but can now confirm that it has more than enough juice to play at satisfyingly loud levels in my 2,000cu ft treated room - all within it’s Class A operating range" James
Note: Class A 30watts goes a long way + well built PSU design stable @ 1ohm load
owners testimonial
Accuphase E650 owners testimonial
"The E650 Class A is not those old Class A feel where the mids are as thick as mud, pace slower than a turtle, lacking in bass, rounding off high frequencies and warmer than sahara desert sonic signature. This E650 has the high frequencies sparkles and amazingly, she has the weight and richness at the high frequencies. The mids and the smoothness are to die for - i might even dare to say, the E650 mids/smoothness are even better than the ML52/53 combo, somehow she presents the mids in FULL richness but never muddying the mids, that memorizing magical Andy William's voice...the Édith Piaf 60's stereo feel, that ever seductive voice of Sandy Posey and Leslie Cheung's husky voice - it's never overly done but it's enough to put a smile on my face. The ML 52/53 shines at neutrality and a real good slave driver when the BASS kicks in......the e650 shines at bringing out the musicality out of the music" Shing, PJ
Latest model 2019 release
* arrived!!
Accuphase A-47 driving the mighty B&W 802D3 in spades
"After listen to a47 for a week , start to realize the difference n beauty of class a amp.Control , lower extension , detail is much more better than my old amp.I am actually surprise the base extension of few cd n record is better than my old 200w amp"
"Had been listening to Accuphase C2150 for last 2 days and first thing I notice is how quiet the background. So quiet until can almost feel like in vacuum room. What I enjoy the most from pre pro is how pronounce the music can be. I had been using audio research tube and before that integrated tube amp. I always appreciate how warm the vocal for tube. Now listening to the Accuphase is how much more dynamic it can be and still have the feel of the tube warm. The best thing I feel about Accuphase is how easy it is to listen. Now with the pre amp it makes the overall sound to feel enveloped. Even my 11 years old B&W suddenly feel like got something new which I didn’t notice before pop up. Guess this is why I still keep it...."
accuphase gives u the convenience without having tube maintenance. Class A is very magical!!!
E-380 is by 20% more powerfull than succession model of E-370, but even more interesting point is evolved AAVA.
AAVA module in the former model E-370 has paralleled the largest two units in “V to I” converters and in E-380 are four. This improvement helps to make the V-I converter amp’s output current double, and it results in reducing the value of the feedback resistors and the noise coming from them. Increased damping factor also play the role with low-sens domestic loudspeakers - DF of E-380 is 500.
[url=https://servimg.com/view/18772933/134][url=https://servimg.com/view/18772933/135][/url][/url]
Accuphase C-2150 ANCC + AAVA Pre + P-4500 Amp - latest iteration model
Review done by hi end Stereo-Magazine, Germany
.."Accuphase has a light and lively sound and treats fine dynamics highly sophisticated.......with such tonal coherence as the C-2150 does....succeeded in a first-class performance with bright colours, perfect representation of the wide spectrum and exemplary tonal integrity....superb purity and silence with the necessary, I repeat, naturalness.."
Owners testimonial
" I have been “looking West when I should have been looking East” ...
This pretty much sums up my HiFi journey to-date. I have just been left wanting more from my existing amp, more from the lower frequency a larger soundstage and that certain Hi-Fi sonic quality ...
Enter the Accuphase E-480 , the moment I heard it out of the box playing Eva Cassidy’s Songbird, I smiled to myself ... everything I was looking for and more ... and this element of “je ne sais quoi”
I had the benefit of home auditioning this product, not many HiFi dealers would acquiesce to such an arrangement , however try it and you will be able to do your own A/B comparison, let your ears be the judge not only from the comfort of your own home where the only variable is the product you are auditioning.
I must also commend the build quality of the Accuphase products they are second to none, from the switches to the knobs ... everything feels precisely engineered and premium ... let’s just say the E-480 is not leaving!
With regards to the champagne finish ... don’t worry, you will get used to it!"
Owners testimonial
"Accuphase E-480 Integrated (latest iteration)
* testimonial by Dr. Azmel
THE SOUND.
Right out of the box, I can sense there is something special about this unit.
As it is a brand-new unit, I need to give it some time to ‘acclimate’ with the new environment.
So I keep the unit on for 24 hours non-stop playing various songs from pop to jazz to instrumental to classical.
You name it.
During the ‘break-in’ period, I notice it to be extremely detail and transparent, casting wide soundstage.
Due to the extra power it possesses, Accuphase grabs my Boenicke and never let it go (Esoteric barely holding the Boenicke together but still manage to caress it to give its best).
Initially I can sense a bit of sibilance on the upper treble which can be quite grating.
My daughter complaints that the sound is too ‘upfront’ and can be rather annoying (once she cried because the music was too loud as I love listening to high volume especially when I am in the kitchen).
This is due to the fact that it is so damn honest.
I admit that my digital fronts can sound ‘too digital’ especially when you crank up the volume (and with the wrong equipment).
The volume knob is so precise that just a slight turn will increase the loudness of the music which is good (I love the smoothness and the precision) but you need to be ‘economical’ about it (slow and steady).
One thing for sure, listening at low volume late at night does not change the nature of the sound.
It still preserves the essence and coherent of the songs.
Not like many other amplifiers when you turn down the volume, it loses the whole definition hence the enjoyment.
My wife said that it can sound too crowded as if the singer and the background music are competing with each other for space (she can’t feel the music penetrating into her soul).
In short, we feel that it is too ‘excited’ or maybe too ‘agitated’ (too aggressive maybe) trying to adapt to the new surroundings.
I let the unit continue to burn (it does feel warm on touch) and calm down.
After one week I notice a significant change in its tonality.
Everything settles down and finally it behaves accordingly.
To test this new ‘behaviour’, I use Spotify and put on some ‘rock kapak’ songs from the 90’s.
I ask my wife and my daughter for their input again.
They simply love it especially my wife.
My daughter said the instruments are so clear and beautifully rendered.
My wife just falls in love with the vocal and the way it integrates with the songs.
It sounds so balance (from all regions) and harmonious.
Never does Spotify (which is MP3) sounds so good.
Then I switch to WAV (CDs that has been burned into hard disk) and the same magic happens.
The details, the soundscape, the focus especially on the vocal, the honesty and the intimacy are so astounding.
There is a tinge of warmness but not to the point of being discoloured (like tubes).
Neutral will be the word.
Everything stays true to the elements of music (the percussion, the plucking of the strings, the sound of the piano keys being strike, the drumming).
No ajinomoto or MSG (as Uncle Roger always says) being added here.
When I take the Esoteric to the task, it just cannot compete with the Accuphase.
Before, I thought Esoteric will at least ‘compete’ with the Accuphase but now it falls flat on the ground.
Accuphase on the other hand tries to lay out everything so accurately inside the sound sphere that you can pick them out individually.
So vivid and lifelike.
In fact, seldom my wife will praise any gears but Accuphase (of course Boenicke) gets her approval (so much so that now she feels the Esoteric is a little bland).
5. In summary.
This is one of the best amplifiers to ever grace my living space.
Nothing short of astounding.
The sounds coming out of the Accuphase is so breathtaking that you want to keep on listening to belting out your favourite songs.
For the asking price of RM35K, it is a lot of money to burn but you will get to own a piece of superbly engineered equipment that will last a lifetime and at the same time enjoy the delightful, insightful and enticing sounds it creates.
I cannot emphasize how great this amplifier is.
I am not going to use the word ‘worth the price’ here but I could say this will be the last amplifier you ever need
Accuphase PS-1230 AC Regenerator rm48k
* 10 US AC Outlet
* output a perfect smooth sinewave with no jagged-ness and squarish sinewave
* noise, impurities and distortion are removed from AC power line in real-time
Different types of power conditioner
1. Passive conditioner
2. Balance Isolation
3. Voltage Regulator
4. AC Regenerator
Owner testimonials
“accuphase ps 1230 clean power supply in the house. totally super quiet now. I mean dead super duper quiet without lost of details.
Without going in audiophile talk - which I tak tahu. = everything comes out lah.
After dinner whacking session.
The accuphase ps 1230 gets even better after 3 weeks. The highs are so well control yet not roll off. No brittle highs. The bass - super tight and accurate. Mids - not need to cakap lah, it's accuphase after all. Me very likely. YMMV.
Hans Zimmer live in Prague - why so serious = wah..... Cukup stim. Seal - stand by me = can Taruk oredi, dulu kenot cause content was noisy. The vocals like Lan Lan all popping out even more and super duper real n when I close my eyes - cukup shiok factor.
Can't wait for 500 hours
Finally, I get to enjoy Soprano at home with full scope of the singer's feeling like in the concert. Nothing beats hearing n feeling the singer's voice in the concert.
From d pp to her minute tonal pitch to her fff. While fff ing.... the audience can feel her emotions and what she wants to convey - happiness, excitement, sorry, anger, surprised.
The accuphase power regen gave me ALL THAT at my own home Macam concert feel.
Cukup terror lah. No wonder decades ago, me accuphase kakis say, the accuphase regen is the holy grail for all accuphase kakis. Only now, I Baru tahu. POWER
Terbaik
Freaking accuphase can ROCK too. She is so quiet that I can finally turn this song up to deafening volume.
PRAT is present too. She ain't one trick pony man. Rock, soprano, pop, vocal (with feel) Semua Boleh.
This song needs no intro lah. Bring it on Slash.
I can feel her sorrow and emotion. WTF man??? (In a +ve manner)
Usually in my limited years of playing stereo set, when Ada emotion and draw = warm n a bit muddy, lacks the whack in d lower region, dark, minimum clarity, lacks air and separation.
But this THING, the accuphase regen power unit...... Fu yoo.......complete transparency, full airyness, the whack at d bass = cukup shiok. And the fluidity Macam water fall. And no sticky mids. Sound stage n depth = super duper lah.
Bestest = with a neutral sounding system, now I can get to feel the emotion, draw and that feeling (感覺)
Almost wanted to cry oredi.
Aka having my cake and eat IT ALL.
GREED IS GOOD - Gordon Gekko.”
#accuphase #yamaha #ns5000
Accuphase made it to the front/feature cover of “Audio Hifi & Home Theater Korea Magazine”
Accuphase P-7500 Power Amp(2022 model)
300W@8ohm 600W@4ohm 900W@2ohm
S/N ratio guaranteed @130db (ultra-low noise amplification)
^ less noise MORE MUSIC
Full review of the latest recently launched Accuphase P-7500 + C-2900
[url=https://servimg.com/view/18772933/220][/url]
[url=https://servimg.com/view/18772933/221][/url]
Accuphase Reference Digital Source
50th Anniversary Special Models
• Accuphase’s Flagship High Rigidity/High-Precision Aluminium machined SACD Transport DP-1000
• Accuphase’s Ultimate DAC DC-1000
^ both house in a exotic wood-veneer high-gloss finish crafted by artisans with high-carbon cast-iron foot insulators
#accuphase
Accuphase E-280 rm22.5k
* ready stock
"The E-280 pulls the ace out of his sleeve again and throws it on the table. He managed to make me listen to that song one more time, then one more time, then one more time… Anyone who has once touched any Accuphase device will know what I’m writing about because that tactile feel can only be compared to a few high-end devices on the market.. " Nebojša Uglješić, reviewer from Croatia
* ready stock
Accuphase A-48 Class A - “instrumentation amplifier design topology”
#accuphase
#accuphase
Congratulations to Accuphase..making it to the front feature cover @ Stereo Magazine, Germany # issue July 2023
Accuphase E-4000 180W Integrated - transistor amplification (trickle-down tech from P-7500 new flagship stereo amp)
Accuphase E-480 180W Integrated - Mosfet amplification (discontinued)
Accuphase E-4000 180W Int -rm40k (ready stocks)
#accuphase #stereomagazine
Hifi Creations
Hifi Creations
Accuphase PS-550 AC Regen (2023 iteration)
- 8 US Outlet
~ Outputs AC “Perfect” Sine Wave - no squarish/jagged sine wave from TNB
~ Regulated output 230Vac
~ Zero harmonic distortion output
Sound test:
* supercharged all the +ve variables to a whole-new level of SQ
* A-MUST HAVE
Full video: [You must be registered and logged in to see this link.]
Hifi Creations
40460 Shah Alam
* kindly call before coming
Hifi Creations
Distributor and exclusive dealer of Accuphase Skogrand Pink Faun Streamer Acoustic Revive
- 8 US Outlet
Sound test:
* A-MUST HAVE
Hifi Creations
40460 Shah Alam
Hifi Creations
Accuphase PS-550 AC Regen - 2023 iteration
^ 8 US Outlet
The SQ jump is substantial. Small nuances will ‘POP’ out..resolution is greatly elevated
Its like ‘veil’ has been lifted up - transparency jump to few notches up.
Quietness of the background is the star of this regen..u HEAR MORE OF EVERYTHING!!
Accu PS-1250 is the next model up (flagship)
Audition available @ Gamuda Biz Suite, Kota Kemuning Shah Alam Selangor
#accuphase
^ 8 US Outlet
#accuphase
Accuphase DP-1000 DC-1000 50th Anniversary Special Model
“WE RECOGNIZED THE DP-1000/DC-1000 SYSTEM to be the ‘best product’ this Japanese company has ever prepared - not only the best digital player, of course, but precisely - the product. It plays every album in an equally wonderful way, giving each performer emotions, energy, but also not allowing the sound to be too bright. I would even say that it is the darkest sounding player from this company, if it did not suggest that it is dark, which it is not. With it we get a lot of information about the treble, but even more about the midrange and bass. Simply top high-end.”WOJCIECH PACUŁA, Hi-Fidelity.PL
→ AWARD: ???????????????? ????????????????????????????????????????????
Facebook.com/hifi-creations
#accuphase
#accuphase
Demo session @ Accuphase Malaysia
“huge and deep soundstage, a layered sound, good imaging and great dynamics, clarity and transparency. On top of that, the music had an organic quality which sounded relaxed, natural and alluring…” Lam Seng Fatt, av2day
#accuphase #pinkfaun
Br
Victor
Hifi Creations
Br
Victor
Hifi Creations
These are the Accuphase Components will be on the upcoming KLAV Hifi Show 2023
We are at Room 2601 Corner room, Level 26
Do ‘ask us’ about special KLAV price
[url=https://servimg.com/view/18772933/283][/url]
[url=https://servimg.com/view/18772933/285][url=https://servimg.com/view/18772933/288][/url][/url]
[url=https://servimg.com/view/18772933/285][url=https://servimg.com/view/18772933/286][/url][/url]
Our humble Accuphase E-4000 180W Integrated(latest iteration) is on duty driving a pair of B&W 802D3(2nd top model) via Pink Faun 2.16 Ultra music server - Tidal Music
Video sampler:
[You must be registered and logged in to see this link.] victor
* appointment based only
#accuphase #pinkfaun #bowerswilkins #streamer
Video sampler:
Share some good news!!!
For your consideration
Update:
Year end sales
* ready stock
Accuphase E-4000 rm43k
Usual selling price rm40k
Year-end sales rm35k
Accuphase E-5000 50th Anniv model Flagship Class AB rm65k
Usual selling pricr rm61.5k
Year-end sales rm54k
Accuphase DP-570 SACD/DAC rm50k
Usual selling pricr rm45k
Year-end sales rm40k
* all items are brand new
3 years warranty
Limited units
Accuphase Pre Power demo units available
Accu P-7500 Class AB
Accu A-48 Class A
Accu P-4500 Class AB
Accu C-2900 Preamp
Accu C-2450 Preamp
Br
Victor
Hifi Creations, Shah Alam
Owners testimonial
“ 3rd day – Monday
• HiFi Creations
This is the granddaddy of them all.
The pinnacle of my visits.
Mr. Victor Pheh was gracious enough to have me in his showroom in Kota Kemuning.
When I entered the room, I was greeted by the golden hues of Accuphase looking so proudly on the rack and floor.
A pair of B&W 802 D3 speakers were standing beside the Accuphase.
Accuphase DC-1000 DAC, Accuphase C-2900 pre-amplifier and Accuphase P-7500 stereo power amplifier together with Pink Faun streamer were used in the demo session.
It took my breath away for the sheer intensity of the music.
Usually when I listen to music, it just caresses my body and soul like a breeze does but here, it gushes over my inner being like a perfect storm.
The music thundered and the bass slammed like tidal waves.
The experience left me wanting more.
Song after song just swept me away to nirvana.
You can feel the power charging through the air, shaking the molecules to its core.
It was like sitting in a stadium listening to live music.
No inhibition, no reservation, no holding back.
It reminded me of Def Leppard’s song, Pour Some Sugar On Me.
Kudos to Mr. Victor Pheh (victory to him).
Time flew when you were having fun.
I promised him I’ll be back (like The Terminator).
All in all, it was a wonderful and rewarding experience.” Dr. Azmel # 20th Dec 2023
Update:
Our demo unit Bowers & Wilkins 802D3 is up for sale
* original box and manual/accessories
included
Our new website is LIVE
“ 3rd day – Monday
• HiFi Creations
Update:
included
Accuphase E-700 35W Class A Integrated
35W@8ohm 70W@4ohm 140W@2ohm 180W@1ohm
(Power double-down X 2 times and stable at 1ohm load..can ‘drive’ most speakers with ease )
* replace and supercedes the discontinued model E-650 30W Class A
Price: rm47k
* preorder available
ETA April 2024
* appointment based
Hifi Creations
Kota Kemuning
Shah Alam
Distributor and exclusive dealer of Accuphase Clarisys Audio Pink Faun Skogrand Acoustic Revive Sumile Murasakino Cart
Dealer of Revival Audio, Harbeth, Lumin
Price: rm47k
ETA April 2024
* appointment based
Hifi Creations
Kota Kemuning
Shah Alam
It was a pleasure to have the ‘elites’ from top senior management of Accuphase to drop by at our showroom.
Members consist of :
Mr. Shigemasa Saito (Founder/Corporate Advisor)
Mr. Masaomi Suzuki (President)
Mr. Takaya Inokuma (Director of Engineering Dept)
Mr. Kohei Nishigawa (Sales Dept)
I played music from “the wind that shakes the barley, Live version from Massey Hall, Toronto, ON” the ethereal hauntingly real melodies on the full stack of Accuphase system got the ‘approval’ from maestro himself, Mr Shigemasa Saito (Founder). Till today i can see he is still a music-lover..he enjoyed the entire curated-playlist which i had prepared for him.
Brief discussion with Mr Masaomi Suzuki(President) i found that he is an avid Apogee owner and fans too. Shared with him that I will be bringing in the all-new “newest & greatest” from Clarisys Audio Fullrange Ribbon Planar speakers. He was absolutely thrilled
Mr Takaya Inokuma (Director of Engineering) was impressed with the overall setup and room acoustics. I can see he is a person who strive for highest-tier of music reproduction. From my limited experience, i shared as many as i can.
Safe travels
Thank you Lam Seng Fatt, Editor of AV2Day for the coverage
Update:
New listening experience!! Soon
Revival Audio, France + Accuphase listening experience @ our new Listening-Lab(soon)
Full line-up of Atalante(demo-ready)
Atalante 3 bookshelf
Atalante 4 floorstander
Atalante 5 Large standmount 12” woofer
Atalante 3 rm15.5k
Accuphase E-280 Integrated rm22k
Total: rm37.5k
Package Price: rm33k
Atalante 4 rm25.8k
Total: rm47.8k
Package Price: rm40k
Atalante 5 rm29.9k
Total: rm51.9k
Package Price: rm43k
[url=https://servimg.com/view/18772933/345][/url]
Atalante 3 rm15.5k
Total: rm37.5k
Atalante 4 rm25.8k
Total: rm47.8k
Atalante 5 rm29.9k
Total: rm51.9k
» Accurate V800 DAC
» New Paradigm Monitor SE 8000F - "Full-blown accurate sound at a low price"
» ( sold )Accuphase C200 Preamp & Accuphase M-60 Mono Block Power Amp(used)
» Accuphase C200L Preamp and Accuphase P300L Power Amp - Sold
» Phase Linear Pre Amp
