Rotel RB-1080 2 Channel Power Amplifier SOLD
Rotel RB-1080 2 Channel Power Amplifier(used)
The RB-1080 rests close to the pinnacle of Rotel's two channel power amplifier designs.
Product Description
The RB-1080 rests close to the pinnacle of Rotel's two channel power amplifier designs. Power output of 200 watts per channel (20 Hz to 20 kHz @ 0.03% THD into 8 ohms) is extraordinary. The Rotel-made toroidal transformer feeds separate power supplies for each channel, each with its own rectifiers, voltage regulators, and capacitor banks. Damping factor, at 1,000, shows this amplifier's unparalleled ability to lock onto the most difficult speakers to precisely control diaphragm motion and give you the best sound quality. Switchable balanced (XLR) and unbalanced (RCA) inputs provide flexible system interface. Front panel heat sinks add a strikingly dramatic look and serve a functional purpose by enhancing heat dissipation even in cramped environments. And a separate input and output for 12 volt "trigger" signals makes this amplifier well suited for fully integrated systems with total remote control capability.
Specifications:
Power output: 200 watts per channel into 8Ω (stereo)
Frequency response: 15Hz to 100kHz
Total harmonic distortion: 0.03%
Damping factor: 500
Input sensitivity: 1.5V
Signal to noise ratio: 116dB
Dimensions: 430 x 139 x 400mm
Weight: 16.8kg
Conditions: 7/10 (USED)
- Number of posts : 5622
» Rotel RB-1080 2-channel power amplifier (Sold)
» Rotel RB-1080 Power Amplifier (SOLD)
» Rotel RB-1080 power amplifier (Used) SOLD
» Rotel Stereo Power Amplifier RB-1080 (used) SOLD
» Rotel RB-1080 power amp (Used) - SOLD
