Akai turntable
Akai turntable
Post by HiFiLab on Fri Oct 12, 2018 10:40 pm
Made In Japan
Product:
Vintage Akai AP-001C turntable.
The Akai AP-001C comes with the original dust cover and a Audio Technica cartridge with stylus.
Including:
- Original Akai AP-001C dust cover
- GT cartridge with stylus
- Power cable
Specifications Akai AP-001C turntable:
- Platter: 300mm aluminium die-cast
- Drive system: belt drive
- Motor: 4-pole synchronous motor
- Speeds: 33 and 45rpm
- Wow and flutter: 0.06% wrms
- Signal to noise ratio: better than 50dB
- Tonearm: static balanced type, stainless steel tubular arm with inside force canceller and lateral balance weight
- Arm length: 220mm
- Cartridge weight range: 4 to 10g (10 to 15g with sub weight)
- Arm lifter: oil damped
- Overhang: 15mm
- Headshell weight: 8g
- Dimensions: 440 x 140 x 350mm
- Weight: 6.3 kg
HiFiLab
Number of posts : 2393
