Denon DCD-800NE CD Player
Denon DCD-800NE CD Player Brand New. Now Selling At RM2,499. Free Shipping Within West Malaysia.
Denon DCD-800NE
Features
Enjoy stereo sound from a variety of CD types with the Denon DCD-800NE CD Player. It uses a Burr Brown PCM1795 digital-to-analog converter for detailed audio reproduction from the stereo RCA analog output, and also features an optical and digital coaxial output. The DCD-800NE will play CDs, CD-R/RWs, and MP3, WMA, and AAC files from CDs and USB drives.
Advanced AL32 Processing Plus
This analog waveform reproduction technology utilizes data interpolation algorithms, which support high-resolution audio sources, to add in the points that should exist before and after large quantities of data to smooth out the waveform and restore information lost during the digital recording. This is designed to produce detailed playback that's free of interference, expressive in the lower range, and faithful to the original sound.
Supports CD, CD-R/RW, MP3, WMA, and USB Playback
Enjoy extended playback support for your high-resolution audio collection. It will play standard CDs as well as CD-R/RWs in audio, MP3, and WMA format; or you can plug in your USB drive to listen to your DSD 2.8/5.6 MHz tracks in high-resolution.
Vibration-Resistant Design for Enhanced Audio
The vibration-resistant design helps mitigate the adverse audio effects of heavy components within amplifiers. The power transformers are installed near the bottom of the CD player and immediately above the insulators to mitigate unwanted vibration.
DAC Master Clock Design
To help the DCD-800NE accurately synchronize digital circuits, it is built with a DAC Master Clock design that treats the DAC as the master when clock signals are supplied. The master clock is immediately adjacent to the DAC, helping to suppress jitter and ensure optimal precision in D/A conversion. It serves as the reference for semiconductor operation and helps optimize digital audio circuitry.
Short Circuit Paths
The circuit patterns of this CD player are engineered to make signal paths as short as possible, helping to reduce interference between circuits and the left and right channels, thereby minimizing the adverse influences on audio signals. This helps provide a clean audio output that's transparent and faithful to the original recording.
Pure Direct Mode
This mode feeds sound directly to the amplifiers by bypassing any processing that might otherwise color the signal to help output clean, detailed, accurate audio.
Optical and Digital Coaxial Output
The DCD-800NE features one optical and one digital coaxial output to connect to the digital inputs of your amplifier or receiver.
SPECIFICATION
Compatible Discs CD, CD-R/RW
File Types Supported CD-R/RW: MP3, WMA, AAC
Number of Channels 2
Frequency Range DSD, Playable: 2 Hz to 100 kHz
PCM, Playable, Sampling Frequency of 192 kHz: 2 Hz to 96 kHz
PCM, Playable, Sampling Frequency of 44.1 kHz: 2 Hz to 20 kHz
Frequency Response DSD, 192 kHz PCM, Playable: 2 Hz to 50 kHz, -3 dB
44.1 kHz PCM, Playable: 2 Hz to 20 kHz
Dynamic Range DSD, 24-Bit PCM: 108 dB
16-Bit PCM: 101 dB
DAC Burr Brown PCM1795 (192 kHz, 32-bit)
Digital Filter AL32 Processing Plus
Signal-to-Noise Ratio 115 dB
THD DSD: 0.0015%
PCM, 24-Bit: 0.002%
PCM, 16-Bit: 0.0025%
Input 1 x USB 2.0 Type-A (front)
Outputs 1 x digital coaxial
1 x optical TOSLINK
1 x gold-plated stereo RCA
Other Connections 1 x 1/8" / 3.5 mm IR control in
1 x 1/8" / 3.5 mm IR control out
Output Level 2.2 V RMS
Digital Output Coaxial: 0.5 Vp-p, 75 Ohms
Optical: -21 to -15 dBm
Supported File Formats WMA: 32/44.1/48 kHz, 48 to 320 kbps
MP3: 32/44.1/48 kHz, 48 to 320 kbps
WAV: 32/44.1/48/88.2/96/176.4/192 kHz
MPEG-4 AAC/M4A/MP4: 32/44.1/48 kHz, 48 to 320 kbps
FLAC: 32/44.1/48/88.2/96/176.4/192 kHz
Apple Lossless (M4A): 32/44.1/48/88.2/96 kHz
AIF/AIFF: 32/44.1/48/88.2/96/176.4/192 kHz
DSD/DSF/DFF: 2.8/5.6 MHz
Laser AlGaAs
Laser Wavelength 780 nm
Signal Type Optical System: 16-bit linear PCM
Sampling Frequency Optical System: 44.1 kHz
Front Panel Construction Aluminum
Power Requirements 120 VAC, 60 Hz
Operating Power Consumption 28 W
Standby Power Consumption 0.2 W
Dimensions (W x H x D) 17.13 x 10.5 x 4.5" / 434 x 107 x 275 mm
Weight 9.9 lb / 4.5 kg
Denon DCD-800NE
Features
- USB DAC operation mode
- Separated rectifier circuit for analog and digital circuitry
- Display dimmer and off options
- CD program, repeat, and random play modes
- Auto power off
Short Circuit Paths
Pure Direct Mode
SPECIFICATION
16-Bit PCM: 101 dB
THD DSD: 0.0015%
PCM, 24-Bit: 0.002%
1 x optical TOSLINK
Laser AlGaAs
- Number of posts : 1342
» Denon PMA-800NE Integrated Amplifier & DNP-800NE Network Player
» Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player
» Denon DCD-800NE CD Player (New)
» Denon DNP-800NE Network Audio Player (New)
» Denon DCD-800NE & Marantz PM6006
