Onkyo A-9010 Integrated Amplifier + Onkyo C-7030 CD Player
Onkyo A-9010 Integrated Amplifier + Onkyo C-7030 CD Player Brand New. Now Selling At RM2,399. Free Shipping Within West Malaysia.
Onkyo A9010
Tuned for the best sound quality at its price, the Onkyo A9010 is first-rate performer.
Sound quality over bells and whistles
The Onkyo A-9010 puts sound quality above features. This means that while you won't find digital inputs and multiple outputs you do get decent quality components fitted. The UK tuned circuitry uses Onkyo's famous WRAT (Wide Range Amplifier Technology) for a precise and dynamic sound. Discrete amplification, using quality components, also ensures low distortion and unrestrained power.
Ready for your record deck
With sales of vinyl on a roll, the Onkyo A9010 hasn't forgotten about your turntable. The built-in MM phono stage is compatible with the majority of turntable cartridges and compliments the sound of the rest of the amp - rich and smooth yet also detailed.
Quality headphone output
By using a dedicated headphone amplifier, the Onkyo delivers; even when your speakers are mute. With substantially more power than a typical portable player, the A9010 gets the best from your headphones - making them sound punchier and more revealing.
Solid construction for a better sound
The Onkyo's rigid chassis and casing not only looks good but also isolates the audio signal from vibrations. Gold-plated speaker terminals accept chunky cable and are internally connected via thick speaker plates rather than speaker relays, for reduced resistance.
System remote
The comprehensive yet logically laid out remote supplied with the A9010 operates a complete Onkyo Hi-Fi system. Navigating between amp, CD and tuner is easy with this intuitive handset.
For an amp that truly connects with the music, the Onkyo A-9010 is a passionate performer.
Onkyo C7030
If it's all-round CD excellence you're after, then you need to take a look at the Onkyo C7030.
Serious about sound
Featuring a high quality Wolfson 192kHz/24-Bit DAC and VLSC (Vector Linear Shaping Circuitry), the C-7030 is a serious performer. Vector Linear Shaping Circuitry smoothes the output for a virtually pulse-noise-free audio signal. When combined with the Wolfson DAC this gives this Onkyo CD player the ability to reveal fine nuances of music that would usually be glossed over.
Generous range of features
As you'd expect from Onkyo, the C7030 leads its class when it comes to features. MP3 encoded discs can be played back, as can CD-RW discs. There's a 25-track memory, along with random and repeat functions. The display has a 3-mode dimmer so it doesn't prove distracting in dimly lit rooms. For personal listening, the headphone socket has its own volume control. Finally, the inclusion of both optical and coaxial digital outputs ensures the C7030 will work with almost any type of DAC digital amplifier or digital recorder.
Superior construction quality
Like all Onkyo products, the C-7030 is superbly finished. An aluminium front panel faces a high-rigidity, 1.6mm thick, anti-resonant chassis for improved vibration resistance.
For a CD player with just the right balance of attributes, the Onkyo C7030 makes the perfect choice.
SPECIFICATION
Onkyo A9010
- Sensitivity: Line 150mV; Phono 3mV
- Impedance: 100kΩ (Line) 47kΩ (Phono)
- Phono Overload: 94mV (MM, 1 kHz, 0.5%)
- Freq Resp: 10Hz−100kHz/+1dB, -3dB
- Speaker Impedance: 4Ω – 16Ω
- Power Out: 44 W/Ch (8Ω, 1kHz, 0.08%)
- Accessories: Manual, remote, 2 x AAA
- Operate Power Consumption: 155 W
- Dimensions (WHD): 435 x 129.5 x 332.5mm
- Weight: 8.0 kg
Onkyo C-7030
- Freq Response: 4Hz–20kHz (-3dB)
- THD/SNR: 0.0029% (107dB)
- Dynamic Range: 100 dB
- Ports: Optical/Coax/Analog
- Power Consumption 12 W
- Dimensions (WHD) 564 x 200 x 413mm
- Weight 7.2 kg
Onkyo A9010
System remote
Onkyo C7030
Serious about sound
SPECIFICATION
Onkyo A9010
- Weight: 8.0 kg
Onkyo C-7030
- Weight 7.2 kg
- Number of posts : 1318
» Onkyo C-7030 CD Player
» Onkyo a9010 / a-9010 amplifier
» Onkyo C-7030 CD Player (SOLD)
» Onkyo C-7030 Compact Disc Player (Used) SOLD
» Onkyo integrated amplifier (used)
