Audio Technica AT-LP120USB Turntable ( Sold )
Type | 3-speed, fully manual operation |
Motor | DC motor |
Drive Method | Direct drive |
Speeds | 33, 45 & 78 RPM |
Pitch Variation | +/-10% or +/-20% |
Turntable Platter | Die-cast aluminum |
Braking System | Electronic brake |
Wow and Flutter | <0.2% WRMS (33 RPM) |
Signal-to-Noise Ratio | >50 dB |
Output Level | Pre-amp "PHONO": 2.5 mV nominal at 1 kHz, 5 cm/sec Pre-amp "LINE": 150 mV nominal at 1 kHz, 5 cm/sec |
Phono Pre-Amp Gain | 36 dB nominal, RIAA equalized |
USB Function | A/D, D/A - 16 bit 44.1 kHz or 48 kHz USB selectable; Computer interface - USB 1.1 Compliant Windows XP, Vista or MAC OSX |
Power Supply Requirements | 230V AC, 60/50 Hz |
Power Consumption | 11W |
Dimensions | 450.0 mm (17.72") W x 352.0 mm (13.86") D x 157.0 mm (6.1") H |
Weight | 10.7 kg (23.5 lbs.) |
Condition : 9/10, All working condition
Packaging material : original
Accessories : Original cartridge AT-95, Original Hinged Cover,
Power cord, operation manuals
Price : RMxxx
Contact : 019-3384067, call, whatapps, SMS
Chew
chewkwokhon- Frequent Contributor
- Number of posts : 318
Registration date : 2009-05-19
» Audio-Technica AT-PL300 Turntable with Box (Used) SOLD
» Audio Technica AT-LP60 turntable (sold)
» Lenco L75 turntable with Audio Technica AT95SE Sold
» [SOLD] Audio-Technica AT-LP5x turntable + AT-VM95E cartridge
» STD 305M Belt-Driven Turntable with Audio Technica AT1120 Tonearm (Used) SOLD
