TEAC NT-505 USB DAC & Network Player
TEAC NT-505 USB DAC & Network Player Brand New. Now Selling At RM6,999. Free Shipping Within West Malaysia.
USB DAC/Network Player
NT-505
Dual monaural USB DAC/Network Player supporting DSD512 and PCM32/768
The NT-505 is a flagship dual monaural USB DAC with versatile network playback capabilities. It successfully incorporates the latest network technologies, along with TEAC’s decades of accumulated audio design experience, in an attractive package with an A4-sized footprint.
Like its predecessor (the NT-503) it employs a dual monaural circuit design to process audio signals with even greater purity, with the latest VERITA AK4497 DAC chip used on each of the two channels. This improves the S/N (signal to noise) ratio by processing each channel individually in monaural mode, as well as delivering DSD512 (22.5MHz) native and 768kHz/32-bit PCM playback capabilities.
The Analog section, which is one of the keys to sound quality, includes four TEAC-HCLD buffer amp circuits that allow different drive modes, - fully-balanced drive for balanced output, and parallel drive mode for unbalanced output - to achieve enhanced acoustic expression.
On the network audio side, the NT-505 supports high-quality music subscription services, namely TIDAL and Qobuz, and is Roon Ready. There’s also a built-in MQA decoder, and you will enjoy unlimited music content on the Internet thanks to its high-quality digital and Analog processing technologies.
In addition to a wide range of digital and Analog inputs, a Bluetooth receiver supporting LDAC and Qualcomm aptX HD allows you to stream high-quality audio wirelessly from your smartphone to this flagship USB DAC.
The NT-505 is a compact and high-spec USB DAC and network player that supports the latest Hi-Res formats and online music subscription services.
Spec description
Supported formats
USB input
PCM 16/24/32 bit
44.1k/48k/88.2k/96k/176.4k/192k/352.8k/384k/705.6k/768k Hz
DSD 2.8M/5.6M/11.2M/22.5M Hz
Coaxial digital input
PCM 16/24 bit
32k/44.1k/48k/88.2k/96k/176.4k/192k Hz
DSD 2.8MHz(supported with 176.4kHz/24-bit DoP format)
Optical digital input
PCM 16/24 bit
DAC section
USB DAC Asahi Kasei Microdevices AK4497×2
Up-conversion up to 384kHz/32-bit PCM, 22.5MHz DSD
Digital filters
PCM filters Sharp Roll Off, Slow Roll Off, Short Delay Sharp, Short Delay Slow, Low Dispersion, off
DSD cutoff frequencies Narrow : 39kHz (at 2.8M), 78kHz (at 5.6M), 156kHz (at 11.2M) or 312kHz (at 22.5M)
Wide : 76kHz (at 2.8M), 152kHz (at 5.6M), 304kHz (at 11.2M) or 608kHz (at 22.5M)
LAN section
Connector RJ-45×1(100Base-T)
MQA Decoder Built-in
Audio inputs
USB (rear) USB B port, USB 2.0, asynchronous mode transfer, bulk transfer
Compatible Software TEAC HR Audio Player (Windows, Macintosh)
COAXIAL digital (rear) RCA pin×1 (gold-plated)
Input level 0.5Vp-p
Input impedance 75Ω
Optical digital (rear) TOS-link×1
Input level -24.0 to -14.5dBm peak
Coaxial digital (front) 1/8” (3.5mm) mini×1 (combined with optical digital input, detected automatically)
Input level 0.5Vp-p
Input impedance 75Ω
* 1/8” Mini - RCA conversion cable included.
Optical digital (front) 1/8” Mini Optical×1 (combined with coaxial digital input, detected automatically)
USB (front) USB A port
Supported media USB Flash Drive
Bluetooth
Bluetooth version 4.0
Output class Class2 (Range: approx. 33ft/10m)
Supported profiles A2DP, AVRCP
Content protection SCMS-T
Supported codec LDAC, Qualcomm aptX HD, aptX, AAC, SBC
No. of paired device maximum 8 devices
Audio outputs
XLR balanced XLR×1 pair (gold-plated)
Output level Fixed (0dB), fixed (+6dB), variable, output off (selectable)
Maximum output leve 2.0Vrms (1kHz, full scale, into 10kΩ, when set to fixed (0dB))
4.0Vrms (1kHz, full scale, into 10kΩ, when set to fixed (+6dB))
12.0Vrms (1kHz, full scale, into 10kΩ, when set to variable)
Output impedance 188Ω
RCA unbalanced RCA pin×1 pair (gold-plated)
6.0Vrms (1kHz, full scale, into 10kΩ, when set to variable)
Output impedance 150Ω
Headphone outputs
Connector 1/4” (6.3mm) Stereo TRS jack×1 (gold-plated)
Polarity Tip:L+, Ring1:R+, Ring3:L-, Sleeve:R-
Maximum output 500mW + 500mW (into 32Ω)
Supported impedances 16 to 600Ω
Clock section
Internal clock
Type Crystal oscillator
Number of clocks 2 (44.1kHz and 48kHz)
External clock input
Connector BNC (gold-plated)
Input frequency 10MHz
Input impedance 50Ω
Input level Rectangle wave: equivalent to TTL levels
Sine wave: 0.5 to 1.0 Vrms
Audio performance
Frequency Response 10 to 80,000 Hz (+1/-3 dB, 192kHz PCM input, RCA output, digital filter off)
Total harmonic distortion 0.002% or less (192kHz PCM input, RCA output, digital filter off)
S/N ratio 110dB or higher (192kHz PCM input, RCA output, digital filter off)
Power supply
US/Canada AC 120V 60Hz
UK/Europe AC 220 to 240V 50Hz
Power consumption 18W (0.4W in standby)
dimensions (including protrusions) 290(W)×81.2(H)×248.7(D) mm / 11.4”(W)×3.2”(H)×9.8”(D)
Weight 3.9kg / 8.6lbs
NT-505
AWARDS
Spec description
Supported formats
USB input
PCM 16/24/32 bit
PCM 16/24 bit
PCM 16/24 bit
DAC section
Digital filters
LAN section
Audio inputs
Input level 0.5Vp-p
Input impedance 75Ω
Input level 0.5Vp-p
Input impedance 75Ω
Bluetooth
Audio outputs
Headphone outputs
Clock section
Internal clock
Input impedance 50Ω
Audio performance
Power supply
- Number of posts : 1342
» Cambridge Audio AXA25 Integrated Amplifier + AXC25 CD Player + MXN10 Network Player
» TEAC NT505 DAC / Network Player
» TEAC NT-505-X USB DAC/Network Player - SOLD
» Teac NT-503 Versatile Network Player with USB DAC (Sold Out)
» Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player + AXN10 Network Player
