Oppo PM-3 Headphones & Oppo HA-2 Portable Headphone Amplifier and DAC (PROMO PACKAGE)(SOLD)
PROMO PACKAGE!!!
SOLD
OPPO PM-3 HEADPHONE
Unique Planar Magnetic Sound
Utilizing planar magnetic drivers derived from the award-winning PM-1 headphones, the PM-3 features deep bass, smooth midrange, and clear treble. The sound signature can be described as very natural and balanced, with plenty of emotion and impact.
Stability, Consistency, Reliability
Many planar magnetic headphones have large balance deviations between the left and right channels, and accurate stereo reproduction is contingent on having a very close match between the left and right channels. During the OPPO PM-3's manufacturing process, drivers are closely matched to ensure optimum stereo imaging and soundstage.
FEM-Optimized Magnet System
An FEM-optimized magnet system with very high energy Neodymium magnets is used to maximize sensitivity and consistency of the applied force over the driver area.
Phase Coherence
When sound enters our ear, it has a planar wave front with all spectrum components in phase. A typical dynamic headphone driver disrupts this coherence with its phase irregularity, resulting in less than perfect signal peak reconstructions. OPPO's planar magnetic driver has much better phase coherency since all parts of the diaphragm are vibrating in concert without break up and delayed resonance.
Double-Sided Spiraling Coils
The diaphragm utilizes a spiraling pattern of flat aluminum conductors on either side of the driver. The double-sided design allows twice as many conductors to be placed within the magnetic field, which leads to higher sensitivity, better damping, and even drive force.
7-Layer Diaphragm
OPPO's planar magnetic driver diaphragm has 7 layers of thin materials that provide excellent performance, reliability, and longevity. The construction of the diaphragm ensures that it is very stable under thermal stress and vibration.
Purely Resistive Impedance
OPPO's planar magnetic driver has a flat conductor pattern that does not have any inductive components. This eliminates inductance related inter-modulation distortion, which is especially common in dynamic drivers with high impedance and a high number of voice coil turns.
Optimized for Mobile Use
Many planar magnetic headphones have a sensitivity far below 100 dB and require very powerful amplifiers to drive. The OPPO PM-3 has a sensitivity of 102 dB, which allows it to be easily driven with mobile devices. Its low impedance works well with smartphones that ship with low impedance ear buds.
Elegant Style
Hi-fi products do not need to look ugly, and stylish products do not need to sound mediocre. The PM-3 sounds excellent, looks beautiful, and is equally at home in the fast-paced urban jungle as in the warmth of a dedicated listening room.
Lightweight and Truly Portable
With a weight of just 320 g, the OPPO PM-3 is the world's first truly portable closed-back planar magnetic headphone. It folds flat and comes with a selvedge denim carrying case. When folded and protected in the carrying case, the PM-3 takes very little space in a briefcase or backpack.
In-line Mic and Remote
The PM-3 is shipped with a 3 meter main cable and a 1.2 meter portable cable. Users can choose the best suitable cable for their mobile devices. Available selections include a cable with mic and controls for Apple devices, one with mic and button for Android and Windows phones, and one without mic.
Unparalleled Comfort
Many planar magnetic headphones weigh over 500 g and are often uncomfortable to wear for more than a short period of time. Thanks to its light weight, plush padding and carefully calibrated clamping force, the OPPO PM-3 is a joy to listen for hours on end.
Material and Build Quality
The OPPO PM-3 is ruggedly constructed with strong metal and plush padding materials. The headphones have been tested to very high standards to withstand mechanical and environmental stress in order to guarantee exceptional performance throughout its lifespan.
Selvedge Denim Carrying Case
The selvedge denim carrying case included with your OPPO headphones is manufactured using vintage shuttle looms by a supplier for a number of boutique clothing brands based in Europe and Japan. The material is a stylish, high-end fabric that is prized for its ability to weather the elements and develop a unique aesthetic character over time, and the slim design of the case is a perfect match with the PM-3’s ability to fold flat, allowing the headphones to fit easily within a backpack or briefcase.
Headphone Specifications
Acoustic Principle : Closed back
Ear Coupling : Circumaural
Nominal Impedance : 26 Ohm
Sensitivity : 102 dB in 1 mW
Clamping Pressure : 5 N
Cable : 3 m detachable cable (3.5 mm with 6.35 mm adapter)
1.2 m detachable cable (3.5 mm)
Cable Connectors : Output: 3.5 mm stereo jack
Input: 6.35 mm stereo jack, 3.5 mm stereo
jack
Weight (without cable) : 320 g (Black/White), 310 g (Cherry
Red/Steel Blue)
Included Accessories : Carrying Case
User Manual
Driver Specifications
Driver Type : Planar Magnetic
Driver Size (Round) : 55 mm diameter
Magnet System : Symmetric push-pull neodymium
Frequency Response In Free-Field : 10 - 50,000 Hz
Long-Term Max Input Power : 500 mW according to IEC 60268-7
Pulse Max Input Power : 2 W
OPPO HA-2 PORTABLE HEADPHONE AMPLIFIER AND DAC
The Oppo HA-2 has a sophisticated design that I didn’t appreciate until I saw it in person. Wrapped in genuine black leather, the HA-2 has a retro vibe. With the volume knob on top, which also functions as the power switch, it reminds me of old portable FM radios, but with a modern flair. The aluminum case has sleek curves and soft bevelled edges with build quality in line with Apple products. The Oppo HA-2 is about the size of an average smartphone at 2.5” x 6.2” x 0.5” and a tad heavier than most at 6.2 oz.
Three inputs make the Oppo HA-2 versatile. On top is an analog input that doubles as the line-out when used as a DAC. On the bottom are a USB A for Apple devices and a USB micro-B for Android and other smartphones with USB OTG (On-The-Go) or a computer. The HA-2 is Apple MFi Certified, ensuring proper compatibility and the ability to pass a digital signal via the Lightning to USB cable. Charging of the unit can be accomplished either via USB to computer or even faster with the included VOOC rapid charging wall plug. Output is accomplished by either the line-out or headphone out, both of which are 3.5mm mini plugs.
Digital Inputs
Making up the rest of the Oppo HA-2’s functionality is an input slider (A,B,C) on the bottom, a battery indicator button and meter made up of 4 green LEDs. The HA-2 also functions has a mobile power bank to charge your smartphone by holding the battery button to enable. On the side is a toggle switch for low and medium gain and a bass boost toggle. The gain control is critical to allow both sensitive in-ear monitors and larger, less efficient headphones to use the same volume control. The bass boost works in the analog domain and when turned off the HA-2 is engineered to provide flat frequency response.
Specification
Brand Name :OPPO
Product Type: Digital-to-analog Audio Converter
Manufacturer: OPPO Digital, Inc
Manufacturer Part Number :HA2
Product Name :Oppo HA-2
Product Model :HA-2
Interfaces-Ports
Headphone :Yes
Number of Analog Audio Inputs: 1
USB Yes:
Technical Information
Features Bass Boost
Maximum Sampling Rate: 384 kHz
Maximum Frequency Response: 20 kHz
Maximum Bit Depth: 32-bit
Physical Characteristics
Material: Aluminium
Width: 68 mm
Depth: 12 mm
Weight Approximate: 175 g
Height: 137 mm
Dimensions: 137 mm (H): 68 mm (W): 12 mm (D)
Miscellaneous
Device Supported Headphone, iPod, iPhone, iPad, iPod touch
RETAIL :RM 3,098.00
NOW ONLY SOLD (postage not included)
Please Contact us at 016-725 5372 ( Wendy ) or 012-6143049 ( Ms.Wee ) for further detail or to arrange for a demo in our showroom situated at Taman Melaka Raya , Melaka.
Mode of payment :
- COD Anywhere in Melaka town area
- PBB / MBB of purchase outside Melaka.
SOLD
OPPO PM-3 HEADPHONE
Phase Coherence
7-Layer Diaphragm
Elegant Style
jack
Red/Steel Blue)
User Manual
Digital Inputs
Specification
Brand Name :OPPO
Product Model :HA-2
Interfaces-Ports
Headphone :Yes
USB Yes:
Features Bass Boost
Material: Aluminium
Width: 68 mm
Depth: 12 mm
Height: 137 mm
Miscellaneous
RETAIL :
Mode of payment :
WTL_Trading- Dealer\Reseller\Trader\Service Provider
- Number of posts : 435
Registration date : 2016-06-29
» Oppo-HA-2-Portable Headphone Amplifier/USB DAC-(New)
» Oppo HA-2 Portable Headphone Amplifier and DAC (New)
» FiiO X5 1st Gen Portable DAP & E12A Portable Headphone Amplifier
» TEAC HA-P50 Portable Headphone Amplifier With USB DAC (Sold Out)
» OPPO HA-2 Headphone Amplifier (NEW) (SOLD)
