Roksan Kandy KA-1 MKIII Integrated Amplifier
Item: Roksan Kandy KA-1 MKIII Integrated Amplifier
Condition: 9/10. Item is in like new condition. 2 months old. With original box and remote control.
Price: sold
Kandy Integrated Amplifier MkIII
The heart of Kandy system, the MkIII amplifier, is equipped with six inputs and a separate tape input, thus accommodating seven source components - one of which is a moving magnet phono stage.
With its 120 Watts per channel power output, the amplifier can partner a wide range of loudspeakers, enabling you to build and expand a system that perfectly matches your preferred sound.
The sound of MkIII is transparent to the device it is amplifying. Partnered by the CD player it delivers a consistent performance characterised by musical fluency, coherent detailing, dynamism and a convincing sense of realism.
Features
Inputs Line Level (x5), Moving Magnet (x1), Tape (x1)
Input Impedance 47 kOhms
Input Sensitivity (115W) Line 470mV
Outputs Speaker L & R (x1), Preamplifier (x2), Tape (x1), Headphone (x1)
Output Power >115 Watts, into 8Ohms both channels driven
>220 Watts, into 4Ohms both channels driven
Power Supply 500VA Ultra Low Noise Toroidal Transformer
4 Regulated Supply Rails
Damping Factor >110 (8Ohms)
Frequency response (-3dB), <3Hz - >100kHz
Gain 38dB Overall (Pre & Power)
7dB Preamplifier
31dB Power Amplifier
Harmonic Distortion <0.005% 1kHz - 8Ohms
Signal to Noise Ratio Line 100dBa (ref 470mV)
Power Source 100V - 120V 50Hz / 60Hz
220V - 240V 50Hz / 60Hz
Power Consumption Standby <25W, Full Power 2-CH 8Ohms < 330 W, 4Ohms <550W
Dimension 432 x 380 x 90 (W x D x H) mm
432 x 380 x 102 (including feet)
Weigth 14 Kg
Price: sold
Features
- Full functional system remote handset
- 6 gold plated RCA line inputs plus tape input
- Line 3 input switchable to MM Phono input
- Gold plated RCA Tape input
- Gold plated RCA Remote output
- Gold plated RCA Pre Amp input
- Head phone output (Gold plated jack)
- L&R Gold Plated speaker output binding posts
- Tape monitor function
- Standby function
- Motorised volume control
- 20dB Mute function
- 50OVA ultra low noise toroidal transformer
- DC output protection
- Short circuit protection (fused)
- 1.6mm solid steel chassis construction
- 6mm solid aluminium front panel
7dB Preamplifier
Weigth 14 Kg
» Roksan Kandy KA-1 MKiii Integrated Amplifier
» Roksan Kandy KMA 2/3 MKIII Power Amplifier
