Audio Physic Yara II Evolution Speakers - Price Reduced
Item: Audio Physic Yara II Evolution Speakers
Condition: 8/10. Item is in very good working condition. A very musical pair of speakers with wide soundstage and tight bass. Excellent built quality.
Price:RM3300 RM2700 RM2500 or swap/topup
The Yara II Evolution is a two-way system that is designed to include two different types of drivers dividing the audio spectrum into two bands – one driver (with center loudspeakers often two) covers the bass/midrange whereas the other one handles the highs. The crossover frequency is normally set between 2000Hz and 3000Hz.
Technical Specs:
Height 950 mm / 38"
Width 170 mm / 6.8"
Depth 230 mm / 9.1"
Weight 13 kg
Recommended amplifier power 20-120 W
Impedance 4 Ohm
Frequency range 42 Hz - 33 kHz
Sensitivity 89 dB
http://www.audioreference.it/docs/audiophysic/suono0912-audiophysic-yaraii.pdf
https://www.connect.de/testbericht/lautsprecher-audio-physic-yara-ii-evolution-center-510928.html
Price:
Technical Specs:
Height 950 mm / 38"
Width 170 mm / 6.8"
Depth 230 mm / 9.1"
Weight 13 kg
Impedance 4 Ohm
Sensitivity 89 dB
» Audio Physic Yara II Evolution Speakers
» Audio Physic Yara II Evolution (Used) SOLD
» Audio Physic Yara Evolution Bookshelf ( Reserve )
» Audio Physic Yara Evolution bookshelf speaker (used)
» Audio Physic Yara Evolution Bookshelves (used) (SOLD)
