Integrated Amplifier Electrocompanient ECi-1 Class A 100W (sold)
I have a extra very less use integrated amp would like to sell off.
It is a true dual mono 100WPC Class A design that can drive any loadspeaker load with very clean and clear class A sound.
All stages designed work in Class A , power supply consist of 2x 500VA toroidal transformers and 40,000 Micro farad smoothing capacitors. Unit in very good working condition.
Technical Specifications ECI 1
Input impedance: 47 kOhm
THD (1kHz 1V input, 1V output) : 0,001% Max.
Channel separation (1V output at 1kHz) :> 90dB Equivalent
input noise :< 3 µV
Output impedance :100 Ohm
Amplifier section Main voltage : 240 V.
Output Impedance (20 Hz - 20 kHz) :< 0,01 Ohm
Input sensitivity for rated output : 0.4 V Max.
Peak current :> 80 A
THD (measured at 1 kHz half power, 8 Ohm): < 0,001 %
THD (measured at 1 kHz -1 dB, 8 Ohm): < 0,001 %
Noise (measured with both inputs shorted) 400Hz - 30kHz : 150 µV 10 Hz - 30 kHz : 180 µV
Output power: 8 Ohm 2 x 100 W, 4 Ohm 2 x 200 W 2, Ohm 2 x 350 W
Power consumption (no load or signal) 161 W
Dimensions Width 432 mm / 17 inches Depth 380mm / 15 inches Height 125mm / 5 inches
(only COD in PJ SS2 area)
Price : RMsold ( negotiable)
Interested please contact me @ Phone: whatApp me at 0123889665 ( Leong)
input noise :< 3 µV
Last edited by pleong on Sat Aug 17, 2019 4:20 pm; edited 1 time in total (Reason for editing : Sold)
pleong- Frequent Contributor
- Number of posts : 181
Registration date : 2018-01-29
» Primare I30 Integrated Amplifier (100W)
» Xtark IA-10 Integrated Amplifier - 100W @ 8 Ohms
» Alchemist Forseti APD15A Integrated Amplifier (100W@8ohms)
» Soul Note SA730 Integrated Amplifier - 100W @ 8 ohms (Made In Japan)
