SOLD - Pro-Ject RPM 9 Turntable (Used)
Pro-Ject RPM 9 Turntable (Used) SOLD
Condition: 8.5 /10 Superb
Upgraded & Rewired with Cardas Tone Arm Cable
Cartridge Not Included
Come with Original Box + Manuals
"The RPM 9 simply sounds so transparent and focused in comparisons to other ‘tables within its price range…The Pro-Ject RPM 9 is a no-nonsense, well-made, attractive turntable that provides sound and build quality that are significantly higher than you’d expect for its $1499 price. It’s rare for me to so thoroughly enjoy using what is nearly a budget-priced component…The Pro-Ject RPM 9 is highly recommended and a choice of this reviewer. " – Jason Thorpe, SOUNDSTAGE
Reviews Links
http://www.soundstage.com/vinyl/vinyl200411.htm
http://www.audioenz.co.nz/2003/project_rpm9.shtml
http://www.hi-fiworld.co.uk/hfw/bgturntables.html
Specifications:
Turntable
• A quiet running AC motor with a two-step pulley drives the platter's outside edge via a belt.
• Ultra thick MDF vestigial plinth stands on three height-adjustable Sorbothane®-damped cones.
• The motor is mounted in a separate metal housing to eliminate vibration transmission.
• The resonance-optimised platter is a sandwich construction utilising a heavy acrylic platter and a brass record puck.
• The inverted bearing uses a stainless-steel axle carrying a ceramic ball on which the ceramic bearing plate runs.
• Central metal block optimises centre of gravity and damps main bearing.
• Connection to the phono input of the amplifier can be made with connecting cables of your taste through the gold plated phono sockets and earth screw
• External power supply avoids potential electro-mechanical interference
Tonearm 9c
• 9" Carbon fibre tone-arm with aluminum head shell
• Conical arm tube avoids standing wave reflections
• Inverted bearing design with four hardened ABEC7 spec ball races
• Solid arm base permits accurate height adjustment of arm tube and VTA (vertical tracing angle)
Was RM6,000 new retail. Now selling Price SOLD
Contact: David
Reviews Links
Specifications:
Turntable
Tonearm 9c
Contact: David
Last edited by pampam on Tue Jul 08, 2014 12:32 pm; edited 4 times in total (Reason for editing : SOLD)
pampam- Frequent Contributor
- Number of posts : 101
» Pro-ject rpm 4 turntable (used) Sold
» Pro-Ject RPM 1 Carbon - turntable SOLD
» Sold-pro-ject turntable RPM-1 Genie 3(used)
» Pro-ject RPM 1 Genie 3 Turntable (Sold)
» Pro-ject Perspective Turntable (used)(sold)
